22221 Discussions
Display 5120 x 2160 @ 50hz using HDMI on Intel Core i7-1165G7
Andrew_i7
Hi All,
According to the i7 specification: intel-core-i71165g7 Spec
Max Resolution (HDMI 2.0b) 4096x2304@60Hz
I need to achieve 5120 x 2160 @ 50hz or at 30Hz using  HDMI 2.0 (max. 18Gbit/s).
Are 5120 px possible @ HDMI @ 30Hz?
What is the max horizontal resolution of HDMI interface @ 50Hz or 30Hz at i7-1165G7 ? Is it hard limited or not?
Many Thanks, Andrew
Keywords: 5K2K 11th IRIS Xe Graphics
Jean_Intel
Hello @Andrew_i7.
Thanks for waiting for a response.
Just letting you know that running 5K at 50hz over HDMI 2.0 is not possible due to bandwidth limitations; however, running 5K at 30hz is possible. Keep in mind that you must load the latest graphics drivers and make sure to install monitor firmware for a proper EDID function.
I hope you find this information useful.
Best regards.
Jean O.
Jean_Intel
Keep in mind that I will move the thread to a forum for these specific issues.
Jean O.
Jean_Intel
Hello @Andrew_i7
To better understand this issue, can you please confirm the following information:
Create a report using the following programs:
Intel®️ System Support Utility (Intel®️ SSU)
Intel Graphics Command Center (Intel GCC)
  • Step 1: Open the Intel Graphics Command Center
  • Step 2: Locate and save the graphics driver report
  • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
  • Are you trying to achieve this resolution on the built-in monitor or external monitor?
  • In case you are using an external, what is the monitor model of the monitor?
Looking forward to hearing from you.
Jean O.
Andrew_i7
Hello Jean,
thank you for the answer.
No, unfortunately I can't.
Reason: I do not own such a 40-inch Monitor until yet.
I own my Notebook with only HDMI (no USB-C DP) and I'd like to buy a monitor with 5120x2160 pixel.
Is it expected to work?
Best regards, Andrew
Andrew_i7
Hello Jean,
as requsted...
1) SSU Report @ built-in monitor
2) GCC Report @ built-in monitor
3) "Are you trying to achieve this resolution on the built-in monitor or external monitor?"
       Answer to 3): external Monitor via HDMI 2.0 (max. 18Gbit/s)
4)  "what is the monitor model of the monitor?"
     Answer to 4):    Lenovo ThinkVision P40w-20, 39.7" Spec Page 1-18
                                   or   Dell UltraSharp U4021QW or    HP Z40c G3
BR Andrew
Jean_Intel
Thanks for your response.
Regarding your question, we have not validated the Intel® Iris® Xe Graphics to work under Display 5120 x 2160 @ 50hz resolution. As per the bandwidth of the HDMI 2.0, it may work. The resolutions we have validated are the ones stated on the product's specifications website (https://ark.intel.com/content/www/us/en/ark/products/208921/intel-core-i71165g7-processor-12m-cache-up-to-4-70-ghz-with-ipu.html).
Also, I found that your system has two different graphics devices: Intel(R) Iris(R) Xe Graphics, and NVIDIA GeForce MX350, due to your system working in a hybrid environment, we can't ensure which of the graphics devices control the HDMI port. For this information, you may need to contact the OEM since they have a better understanding of how the system works.
Jean O.
Andrew_i7
Hello Jean,
Monitor @ HDMI2.0 @ Intel Core i7-1165G7:
1) Please, can you check if more then 4096 horizontal pixels are supported?
2) What are the maximum Pixel Clock supported?
Many thanks for your time,
Andrew
Jean_Intel
Jean O.
Jean_Intel
Hello @Andrew_i7.
Best regards.
Jean O.
Jean_Intel
Hello @Andrew_i7.
I am glad to hear that the question is now answered.
If you need any additional information, please, submit a new question as this thread will no longer be monitored.
Jean O.
5120x2160
ich möchte das kaufen
AlHill
Then go to a store and buy it.
