22671 ディスカッション
Display driver's won't update
EEric5
ビギナー
3,332件の閲覧回数
Hi Guy's sorry to bother you with this but can't seem to find a solution to get my drivers to update after the windows 10 install
I have a Toshiba Satellite L455-S5009
I am just trying to play Minecraft and I get this error from Minecraft itself
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bcx.ap(SourceFile:598)
at bcx.an(SourceFile:434)
at bcx.a(SourceFile:381)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.10.2
Operating System: Windows 10 (amd64) version 10.0
Java Version: 1.8.0_91, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 49207856 bytes (46 MB) / 151924736 bytes (144 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.10.2
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU:
and I get a little box that pops up saying I need to update my drivers . When go to do that it says I don't meet the minimum requirements . I'll attach my system info for and solutions you can provide. Hopefully I gave/told you enough
0 件の賞賛
1 解決策
従業員
1,772件の閲覧回数
I have checked computer specifications and integrates an Intel® 4 series chipset but this is not compatible with Windows® 10.
You will have several issues because you will not find proper drivers to work with Windows® 10. I would recommend reinstalling a supported operating system for your Intel® chipset and computer model.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html
Allan.
元の投稿で解決策を見る
3 返答(返信)
従業員
1,773件の閲覧回数
Allan.
EEric5
ビギナー
1,772件の閲覧回数
Hi Allan ,
Thank you for taking the time out to answer my question I really appreciate it, My computer is well past the 30 day mark where I can go back to windows 7 I was wondering if you or someone else from intel could offer some other suggestions . I do appreciate anytime given to this post by you and any other intel people
従業員
1,772件の閲覧回数
You could probably use the Toshiba recovery disc, if you do not have one, please check with Toshiba to see if your computer model should come with a recovery partition or DVD.
https://support.toshiba.com/repair https://support.toshiba.com/repair
Try getting inbox drivers provided by Microsoft* when you keep your system up to date
https://support.microsoft.com/en-us/help/12373/windows-update-faq https://support.microsoft.com/en-us/help/12373/windows-update-faq
Allan.
返信
