23095 Discussions
Displayport not working with LG 7.9" LP079QX1-SP0V
WBae
I wonder why intel HD graphic with display port option is not recognizing 1536 X 2048(vertical) resolution. The system is equipped with intel celeron mailto:N2930@1.83GHz N2930@1.83GHz. Is there any reason for this? What would be a solution for this. I have LG LP079QX1-SP0V Monitor and can't have the monitor working with intel HD graphic. For your reference, Nevidia GTX 760 is working fine with this monitor. Is this the driver problem? Please help me with a solution.
Wook
Allan_J_Intel1
The graphics controller can go up to 2560x1600 at 60 Hz depending on the computer manufacturer.
https://www-ssl.intel.com/content/www/us/en/embedded/products/bay-trail/pentium-n3520-j2850-celeron-n2920-n2820-n2815-n2806-j1850-j1750-datasheet.html https://www-ssl.intel.com/content/www/us/en/embedded/products/bay-trail/pentium-n3520-j2850-celeron-n2920-n2820-n2815-n2806-j1850-j1750-datasheet.html
Please provide your computer model and the graphics report generated within graphics control panel
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics Drivers — Intel® Graphics Driver Report
Allan.
Not applicable
Hi W.Bae,
Most important thing to understand here is that on Baytrail, only DP supports resolution up-to 2560x1600. HDMI only supports up-to 1920x1200.
I'm considering you have connected it using the DP port only.
Here is the breakdown:-
eDP1.3 10.8Gbps (x4 2.7G) supports upto 2560x1600x24@60
DP 1.1 10.8Gbps (x4 2.7G) supports upto 2560x1600x24@60
HDMI 1.4a 148.5 MHz supports upto 1080p@60
Now to attain a resolution of 1536x2048 we need to set custom resolution. But on Baytrail custom modes addition is not supported on LFP/ Digital interface HDMI /DP.
WBae
Do you mean that there is no way to have custom resolution with mailto:N2930@1.83GHz N2930@1.83GHz?
Not applicable
Hi W.Bae,
We are working on this issue to get more clarification. We'll get back to this thread when I see some outcome.
ANoba1
Same issue with i7-4770 (HD 4600).
Allan_J_Intel1
Do you have scaling issues? Please note that N2930 processor model uses different technology that the i7 model.
Allan.
ANoba1
"Different technology", same problem.
Always black screen. (BIOS, Linux, Win 95 - Win 10)
Display works perfect with AMD APU A10-6800K, Nvidia GTX 980 ti and USB GPU.
Allan_J_Intel1
Please test driver version 4463
https://downloadcenter.intel.com/download/26079/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81497 Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
Let me know your findings.
Allan.
