22849 Discussions
Does Intel HD 530 graphics controller support Display Port 1.2 --> MST (Multi Stream Transport)?
PSupp2
like the title asks, i want to know if Intel HD 530 supports DisplayPort 1.2 MST (Multi Stream Transport) --> Using 2 Monitors on one DisplayPort in a chain with 2 individual desktops?
I tried it but it doesn't work with my Intel OnBoard-GraphicCard, only with my AMD GraphicCard, is there a way to get this working?
Thanks in advance,
Peter
Hello Suter,
I understand you would like to know if Intel HD Graphics 530 supports or not Multi-Stream Transport (MST).
Let me apologize for any inconvenience this issue may be causing to you.
Yes, our graphics controller supports Multi-Stream Transport (MST). You can confirm that information on this document page 36 http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/desktop-6th-gen-core-family-datasheet-vol-1.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/desktop-6th-gen-core-family-datasheet-vol-1.pdf
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
What are the screen resolutions you are trying to use with the monitors?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred
MM16
Hi Fred, please see my related question about MST support here https://forums.intel.com/s/question/0D50P00004NfPBoSAN/which-intel-hd-gpu-models-support-8k-monitor-eg-dell-up3218k-via-dualdisplayport-14-cable - my question is which Intel HD graphics models can drive a 8K@60Hz monitor via TWO Displayport 1.4:s, can't find this info anywhere. Thanks!
n_scott_pearson
Intel's existing processors support DisplayPort 1.2, not 1.4. I would presume that, if DisplayPort 1.4 is a requirement, then no, Intel HD Graphics is not going to support this 8K mode.
Hello Suter,
I was wondering if you still need assistance regarding Multi-Stream Transport (MST) on Intel HD Graphics 530. If you still need assistance just let me know.
Fred
