22970 Discussions
Does the intel (arca770) support 10bit color?
korea777
Does the intel (arc a770) support 10bit color?
(intel arc a770) I didn't see any information about 10bit color support.
Is there any way to set it up?
Or is it not possible to support 10bit color?
MUC
Honored Contributor I
If it works for the NUC with Iris Xe then it should also work for A770. If you select your desired resolution and then activate HDR within windows, you should get a 10-bit output like I tested/listed here:
community.intel.com/t5/Graphics/HDMI-Resync-fails-10-bpc-12-bpc-on-NUC11TNKv7-Tiger-Lake-UP3-GT2/m-p/1434976#M111599
But be careful when using adapter cables. If you read the linked thread you'll see that this can be tricky.
philipswilliam23
Philips here,
I am facing same problem like this
What about 10bit color on Intel's (arc a770) processor?
There is no information about 10bit color support on the Intel Arc 770.
Can it be set up?
Does 10bit color support not exist?
