23105 Discussions
Does the intel-drm support the SVM through the IOMMU and PASID?
JLee146
Hi, I am a newbie on the intel-gfx and tries to use the shared virtual memory
which is mentioned in several intel documents (http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/vt-directed-io-spec.pdf vt-d and https://01.org/sites/default/files/documentation/intel-gfx-prm-osrc-skl-vol05-memory_views.pdf Intel-gfx-prm).
Following the above two documents,
shared virtual memory is supported as part of VT-d functionality, and
in detail, IOMMU walks the PASID table and translates the virtual address to physical address
for the PCIe connected devices including the integrated GPUs.
Following the https://software.intel.com/en-us/articles/opencl-20-shared-virtual-memory-overview Intel document ,
It seems that clSVMAlloc is a OpenCL function for zero copy,
but after I've checked the repository of the opencl-intel (beignet),
I found that it never calls any driver functions for managing PASID table.
Is the current intel-gfx supports the shared virtual memory
If the clSVMAlloc is not a right library function for SVM through
PASID and IOMMU, is there a function that satisfies my intention?
Best regards
Jaehyuk.
Hi Jaehyuk,
I understand you have some questions about Dynamic video memory. It seems you are a software developer.
My best recommendation would be contacting appropriate channel of support. At this stage, I recommend checking with our software developer department at
https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
Hope this is useful.
Allan.
