22871 Discussions
Does the intel graphics 620 support dual 2560x1440 monitors?
IGrah
I'm currently working with a new Lenovo ThinkPad X1 Carbon, with a docking station and two older monitors (1920x1080).  I would like to upgrade to dual 2560x1440 monitors but I'm not sure if it would be supported by the video card?
My computer specs are as follows:
i7-8650U CPU @ 1.9GHz 2.11 GHz
16.0 GB installed RAM
64-bit operating system, x64-based processor​
As a secondary question, could this video card have sufficient bandwidth to operate two 4K monitors or is this asking too much?
VARADHARAJAN
Valued Contributor II
IGrah
​Thanks for your response
From what I gather, the maximum resolutions is 4096x2304.  I suspect that this means the card will not support two 2560x1440 monitors.  However, I'm not that savvy with computers so I'm not sure if this is correct.  Am I correctly interpreting the spec sheet?
I found a previous post (see below) where someone wanted to use a 4K monitor and a 2560x1080 monitor together.  The response was that "due to limited bandwidth", the 4K resolution would have to be reduced to 2560x1080 so that the second monitor could be set at the same.  That suggests to me that two 2560x1440 monitors will work?  Is this correct?
Previous post "Dual monitors with 4k screen, 2560 x 1080 resolutions on Intel HD Graphics 620"
Diego_S_Intel
Hello IGrah, Thank you for contacting our Intel® communities. In this case, your CPU will natively support up to: Displays Supported : 3 Max Resolution (HDMI 1.4): 4096x2304@24Hz Max Resolution (DP): 4096x2304@60Hz Max Resolution (eDP - Integrated Flat Panel): 4096x2304@60Hz It will all depend on the type cable, port and docking that you use. In order to address your questions, please contact your computer manufacturer, Lenovo* in this case, so they can provide you with more information regarding their system limitations and hardware requirements. Here is Lenovo's* direct link: https://lenovo.secure.force.com/livechat/apex/LiveChat_all_PreChat_Window_Chatbox_Poup?endpoint=https%3A%2F%2Flenovo.secure.force.com%2Flivechat%2Fapex%2FLiveChat_Queue_Page_All_Chatbox_Popup%3Flanguage%3D%23deployment_id%3D572140000000T45%26org_id%3D00D30000000V2Wu%26button_id%3D573140000000TSi%26session_id%3Df7b81dee-1fee-4dcf-9c17-394de819beac I hope this helps. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
n_scott_pearson
Reinforcing, yes, the processor's engine can support up to three 2K/4K monitors. Whether you can do so with the ports that you have available on your laptop and/or on this docking station is the question - and this is a question that you will need to ask Lenovo about.
Diego_S_Intel
Hello IGrah, We just wanted to double check if you still need further assistance. Please don’t hesitate on contacting us back. I hope to hear from you soon. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
IGrah
Thanks for the follow-up. I decided to go with a single-larger-wide-screen monitor @ 21:9 instead of two @ 16:9. I don’t get as much screen area but the pixel density is the same and I do eliminate the middle bezel Sincerely, Ian Graham, M.Eng. P.Eng. President [cid:image001.jpg@01D4AC02.080B3010] making your ideas concrete aeconcrete.com<http://www.aeconcrete.com/> Cell 604-240-7226 Direct 604-575-7245
