23257 Discussions
Driver 4627 have problem with cemu emulator 4590 work perfectly
hhau
In the 4627 driver it have no graphic problem when open the game first time but when closing cemu emulator it will create shader then when you open it again it will need to compling the shader and the graphic is messed up (Untitled.png)
The 4590 driver not have this problem (Untitled2.png)
My specs:
Intel i5 6400(intel hd 530)
ram 8gb
windows 10
Hello hjymnol,
I understand that Cemu Emulator works with graphics driver 4590, but it does not work with graphics driver 4627.
Let me apologize for any inconvenience this issue may be causing to you.
Thanks for the feedback you are providing to us.
Since this is an application the developer has not validated for our graphics controllers the best option would be keep using graphics driver version 4590. This link will provide more information about application compatibility on Intel graphics controllers http://cemu.info/index.html http://cemu.info/index.html
Fred
Hello hjymnol,
Fred
hhau
I know that cemu is not offically support intel hd but the old driver work very well and i don't want to install old driver everytime to get cemu work (i still need new driver to get sniper elite 4 work better) .So i hope you guys can fix this in the new driver
Hello hjymnol,
If you need to keep using Cemu Emulator the best option would be to keep using driver version 4590.
You can also try contacting the Cemu Community so they can let you know if there is or not any workaround available you can use. This link will give you their contact information http://cemu.info/community.html http://cemu.info/community.html
Fred
