Gostaria de registrar minha reclamação em relação a um problema que está me incomodando muito. A resolução da minha tela não é mais suportada pela placa de vídeo integrada (Intel Iris Xe Graphics) do meu PC no sistema operacional Windows 10. Ela suportava perfeitamente a resolução de 2560x1080 e desde uma atualização de driver ela já não suporta, e mesmo ao tentar criar uma resolução personalizada (com o Centro de comando de gráficos Intel) não obtém sucesso. A resolução máxima permitida é a de 1920x1080 e minha tela está distorcida e com as letras esticadas (o que me incomoda muito e me traz dores de cabeça).
Translate: I would like to register my complaint regarding a problem that is bothering me a lot. My screen resolution is no longer supported by the integrated video card (Intel Iris Xe Graphics) of my PC on Windows 10 operating system. It perfectly supported 2560x1080 resolution and since a driver update it no longer supports it, and even trying to create a custom resolution (with the Intel Graphics Command Center) is unsuccessful. The maximum allowed resolution is 1920x1080 and my screen is distorted and the letters are stretched (which bothers me a lot and gives me headaches).
Hello GUI777
Thank you for posing on the Intel Communities. I am sorry that you are experiencing issue when trying to set your resolution to 2560x1080. I would like to get the following information in order to assist you:
- What is the driver version that previously allowed this configuration and what is the driver that does not allow for this resolution to be set?
- What is your monitor's make and model?
- What type of connection do you use (HDMI, DP)?
- Create a log file with the Intel® System Support Utility and attach it.
Hugo O.
Também tive problema com isso, vou fazer de tudo para evitar a Intel, coisa de baixíssimo nível fazer esses downgrade
I am having almost the same problem with a Samsung G5 Ultrawide Monitor.
But my notebook is new. I have another dell notebook where this monitor uses 3440x1440 resolution.
I am using version 31.0.101.4091 of the Iris Xe Graphics driver.
My monitor is a Samsung Odyssey G5 - C34G55TWWL 34'.
I use HDMI.
I´ve attached the requested log file.
Hello GUI777
I hope you are doing fine.
Hugo O.
Hello GUI777
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Olá Hugo,
Estou com o mesmo problema, tenho um Notebook DELL inspirion i15-i1100-A40P, com uma placa de vídeo integrada Intel(R) Iris(R) Xe Graphics 31.0.101.4502, eu utilizo um segundo monitor ULTRAWIDE (Resolução: UltraWide™ Full HD (2560x1080)), até ontem (13/09/23) estava funcionando normalmente, hoje ao reiniciar o notebook a resolução recomendada para o segundo monitor é de 1920x1080, eu atualizei os drivers dos dois monitores e reiniciei novamente, porém o erro persiste.
- Qual a versão do driver que anteriormente permitia esta configuração e qual o driver que não permite definir esta resolução? Drive atual (atualizado hoje 14/09/23): 31.0.101.4502
- Qual a marca e modelo do seu monitor?LG 25UM58-PF Ultrawide - Monitor Gamer LED 25" Full HD
- Que tipo de conexão você usa (HDMI, DP)?HDMI
- Crie um arquivo de log com o Utilitário de suporte do sistema Intel® e anexe-o. ANEXO OK
Atenciosamente,
Fábio R.
Cliente quase que insatisfeito ;-;
Estou com o mesmo problema, tenho um Notebook DELL com uma placa de vídeo integrada Intel(R) Iris(R) Xe Graphics , eu utilizo um segundo monitor ULTRAWIDE (Resolução: UltraWide™ Full HD (2560x1080)), até ontem (13/09/23) estava funcionando normalmente, hoje ao reiniciar o notebook a resolução recomendada para o segundo monitor é de 1920x1080, eu atualizei os drivers dos dois monitores e reiniciei novamente, porém o erro persiste.
Mesmo problema, mesma situação e equipamentos semelhantes
Estou com o mesmo problema, tenho um Notebook DELL vostro 15 3510 i15, com uma placa de vídeo integrada Intel(R) Iris(R) Xe Graphics 31.0.101.4502, eu utilizo um segundo monitor ULTRAWIDE (Resolução: UltraWide™ Full HD (2560x1080)), até ontem (13/09/23) estava funcionando normalmente, hoje ao reiniciar o notebook a resolução recomendada para o segundo monitor é de 1920x1080, eu atualizei os drivers dos dois monitores e reiniciei novamente, porém o erro persiste.
- Qual a marca e modelo do seu monitor?LG 25UM65-P Ultrawide - Monitor 25" Full HD
Atenciosamente,
Guilherme Alves
@Guilherme89 e @Washingtontais
Eu ainda não consegui resolver meu problema mas estou correndo para achar a solução, caso consiga retorno aqui para avisa-los pois esse tópico aqui já foi encerrado e os suportes da Intel não estão verificando mais...
Me tirem uma dúvida, antes do problema aparecer vocês receberam alguma atualização do próprio Windows? O meu antes de dar o problema estava com atualização, ai ao desligar o notebook ele ficou atualizando e no dia seguinte ao entrar deu esse problema (isso aconteceu comigo), se aconteceu com vocês também podemos desconfiar que foi essa atualização que ferrou com tudo...
De qualquer forma sigo a procura da solução...
Att;
Fábio Rafael
Olá Senhores,
@Guilherme89 @Washingtontais @EduardoMartinelli @GUI777 @Phillype
Tive retorno em outro tópico que eu mesmo abri, o Suporte da INTEL informou que "Por algum motivo, o OEM limitou a resolução nesta porta HDMI", entrei em contato com a DELL para tentar se informar melhor. E não é boa noticia...
O SUPORTE DELL, informou que a entrada HDMI dessa versão de notebook não suporta monitores de 2K, notebooks versão INSPIRION dessa geração não tem entrada HDMI para 2K nem 4K, máxima resolução é 1920x1080.
De qualquer forma espero ter ajudado vocês...
Att;
Obrigado @Rafahh ,
Realmente não é uma boa notícia, A DELL perdeu muitos pontos aqui, mas é uma resposta.
Boa semana.
Abraços.
Hi Hugo, Hi have the same problema as Gui_7777
- Actual Driver: 31.0.101.4091
Previous one: 30.0.101.1338
- LG 25UM58-PF Ultrawide - Monitor Gamer LED 25" Full HD , Preto
- HDMI
- Its attached
Olá eu enfrentei esse mesmo problema no Windows ano passado quando comprei meu monitor
https://drive.google.com/file/d/1yjiJWADefEtEMzG3thnv8kKDyC5HYxSe/view?usp=sharing
esse link é do ultimo driver da intel para esses processadores intelXe que reconhece perfeitamente o monitor ultrawide, agora eu estou procurando uma solução para isso no linux
Boa noite @HenryGZ .
Estou com o mesmo problema em casa. Até então eu sempre revertia o driver do meu computador, mas por algum motivo desta vez ele perdeu todos os pontos de restauração de sistema. Agora estou vendido como a maior parte do pessoal deste tópico.
Eu baixei o driver que vc colocou o link, mas não sei como devo proceder para instalar. Pelo que eu entendi eu preciso desinstalar o driver atual pra depois instalar este, mas não sei como proceder.
Alguém poderia me ajudar neste procedimento?
Olá @Robson , o arquivo que está no link é um executavel, é possivel apenas executar e rodar a atualização/downgrade do driver, mas eu costumo descompactar o arquivo com o 7zip ( https://www.7-zip.org/ ) e rodar o instalador que aparece na pasta, geralmente funciona melhor assim, depois apenas seguir os passos da intel, ele provavelmente vai detectar que já existe um driver mais recente e lhe perguntar se quer mesmo prosseguir. No caso de atualizações do windows que atualizam novamente o driver faz tempo que nao ocorre comigo, mas recorrentemente elas ocorrem e eu tenho que realizar novamente de forma manual o downgrade do driver.
@HenryGZ , muito obrigado!
Deu muito certo. Funcionou perfeitamente. Vou deixar isso separado para não ter mais problemas com futuras atualizações.
Valeu!
