19501 Discussions
Driver gráfico da intel não baixa
Peplow
Quando vou baixar a versão mais recente do driver nunca sai do 0%, e já cheguei a deixar a noite toda tentando baixar mas nada mudou. Tem alguma solução pra isso?
Steven_Intel
Thank you for your response.
I am glad to know you were able to install the driver. Since the thread is solved, we will proceed to close it now.
Please keep in mind that this thread will no longer be monitored by Intel. I appreciate your understanding.
Steven G.
AlHill
Explain your problem in more detail.
What graphics?
What is your processor model number?
What is your devise/system model number?
What operating system/version?
Peplow
Minhas configurações são Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz x64 Windows 10 pro versão 21H2 (10.0.19044), estou com o driver Intel(R) HD Graphics 620 (25.20.100.6444) e estava tentando atualizar para o mais atual (31.0.101.3413/31.0.101.2111). Já tentei várias vezes e nunca sai do 0%.
AlHill
Is this a laptop or desktop?  Provide the complete model number.
Peplow
Desktop-s26msta
Aspire a315-53
AlHill
You did not explain your problem with detail as I asked.
You did not provide your processor model number.
You did not provide your operating system and version.
And, I am unclear on whether you have a laptop, desktop, or both.
I am concerned about you attempting to update your device.
The best solution is for you to take it to a repair shop and have them update it for you.
Peplow
Lhe mostrei todas as configurações logo acima.
Meu problema não é muito complexo, eu apenas fui baixar a versão mais atual do driver e simplesmente não baixa pois não sai do 0%.
Steven_Intel
Hello Peplow,
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Could you please confirm how are you trying to download the driver? Are you using the Intel® Driver & Support Assistant or are you doing it manually?
As well, could you please confirm if you have tried different browsers?
Steven G.
Peplow
Hello Steven, I used the Intel Driver & Suport Assistent and recommended me to intall version 31.0.101.3413, wich it's more than 1gb and I hadn't noticed that my local disk was out of space for installation. So, I expanded it and the installation finally started.
Thank you for attention anyway ;).
Steven_Intel
Steven G.
