22871 Discussions
Dual screens randomly twitch to black for 2-5 seconds
RickF
I have dual screens. They each randomly twitch to black for 1-5 seconds.  Not at the same time
MUC
Honored Contributor I
Please use cables that have a DisplayPort connector on both ends.
MUC
To make an assessment possible, please provide the make and model of your computer, the make and model of your monitors, and the manufacturer and type (USB-C/DisplayPort/HDMI) of cables you are using.
RickF
Dell Optiplex 7010
Processor 13th Gen Intel(R) Core(TM) i7-13700 2.10 GHz
Installed RAM 32.0 GB (31.7 GB usable)
System type 64-bit operating system, x64-based processor
Edition Windows 11 Pro
Version 23H2
Installed on ‎12/‎19/‎2023
OS build 22631.4460
Experience Windows Feature Experience Pack 1000.22700.1047.0
Monitors - 2xSamsung LF27T450F
Cables - DP to HDMI
MUC
Samsung F27T45
1920 x 1080 @ 75 Hz
2 x HDMI 1.4, 1 x DisplayPort 1.2
If your Dell PC has two DisplayPort outputs, I would recommend connecting the two monitors with a DisplayPort cable each to have a straight connection. And please then set up the monitors in the On Screen Display menu as follows:
RickF
I believe that's how I have it setup.  I have two DPs. Each monitor is connected with a DP to HDMI cable.  If that's not the same, can you break it down simpler for me?
MUC
RickF
OK. I will try that. Thank you for the diagram.
RickF
This worked. Thank you
n_scott_pearson
Have you verified that the firmware for the DP-to-HDMI cables is the latest? If it's not, I would be updating it as this would be the usual cause of HDMI connection loss issues (which is what you are seeing).
[Aside: I don't recommend purchasing DP-to-HDMI cables that do not have the ability to have their firmware updated.]
Hope this helps,
RickF
I never heard of cables with firmware.  I have to assume mine do not.
n_scott_pearson
Every one of these cables has a processor that is performing the protocol conversion from DisplayPort to HDMI and most of these implement this protocol conversion using embedded firmware. It is a question of whether or not a particular cable has a method for updating this firmware and is making firmware upgrades available as issues are identified.
RickF
Understood.  These are from a company called UNI.  From amazon. How would I know/confirm that the firmware could be updated?
n_scott_pearson
I went to their site (https://uniaccessories.com/) to check, but didn't see any support for firmware download/upgrade. You could try contacting their tech. support and see if they have any guidance for this.
RickF
I ordered DP to DP cables and the issues in now fixed. Thank you
