22873 Discussions
Elden ring night Reign Crash on Start up
Rudra2
Made Several post in past , problem still persist  New driver don't Fix the problem
Game starts and crashes in 5 sec with white screen  : - Elden ring night reign Crash video
Log file From EVENT  VIEWER : -
Faulting application name: nightreign.exe, version: 1.1.4.0, time stamp: 0x685bd45b
Faulting module name: igd12um64xel.dll, version: 32.0.101.6972, time stamp: 0x687ab8cd
Exception code: 0xc0000005
Fault offset: 0x0000000000095f70
Faulting process id: 0x167C
Faulting application start time: 0x1DBFEF1818197FB
Faulting application path: F:\ELDEN RING NIGHTREIGN\nightreign.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_5f5515ba1a5763b7\igd12um64xel.dll
Report Id: 94e37e56-8aa8-4e10-8404-122d985e7879
Faulting package full name:
Faulting package-relative application ID:
Log clearly suggest  Driver module are at fault : - "igd12um64xel.dll" and has access violation related problem as code suggest : "0xc0000005"
FOR INTEL TEAM TO REPLICATE CRASH :- To Be sure that Drivers are causing error
When the game is launched , when graphics card is disabled through device manager , the game boot into the menu with 5-6 fps ,
At the same time if you try to enable the graphics card while the game is running in background , the game will crash instantly , this clearly suggest something is wrong with drivers itself
Elden ring night reign still runs on Direct X 12 not using newer levels like 12.1 , which suggest that game should run fine
I would Highly Appreciate if intel team tries to replicate this issue and Find a fix or work around , rather than just mentioning "INTEL IRIS XE DOESNT MEET MINIMUM REQUIREMENTS"
SalesDW
up
Thorny
Up
FIX_NIGHTREIGN
up
RafaelBombinha
up
