I bought a brand new Samsung M5 monitor and I would like some help to troubleshoot this issue before I have to disassambly my whole setup to visit the tech support.
The thing is that the external monitor randomly goes black for a second and then recovers. It can flash twice in a short period, a few seconds later flashes once or twice again, and so on. There is no noticeable pattern.
So I'm using Ubuntu 24.04 in a Lenovo IdeaPad Slim 5 with Intel Graphics RPL-P. I could tell it shouldn't be a hardware problem because 1) I used to have another monitor and had no issues, 2) I already tested a couple of different cables with no changes in the behavior, and 3) it also works perfectly well in Windows (dual boot).
Here are some command outputs I've found so far in my useless research. Also I attach the txt file generated by SSU.
$ LANG=C inxi -Fxxxrzc0 --usb System: Kernel: 6.8.0-38-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0 clocksource: tsc Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell tools: gsd-screensaver-proxy dm: GDM3 v: 46.0 Distro: Ubuntu 24.04 LTS (Noble Numbat) Graphics: Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Lenovo driver: i915 v: kernel arch: Gen-13 ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:a7a8 class-ID: 0300 Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-5:5 chip-ID: 5986:215f class-ID: fe01 serial: <filter> Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 compositor: gnome-shell driver: X: loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x2280 s-dpi: 96 s-size: 508x603mm (20.00x23.74") s-diag: 788mm (31.04") Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top model: Samsung Smart M50C serial: <filter> res: 1920x1080 hz: 60 dpi: 70 size: 698x392mm (27.48x15.43") diag: 690mm (27.2") modes: max: 1920x1080 min: 640x480 Monitor-2: eDP-1 pos: primary,bottom model: BOE Display 0x0b76 res: 1920x1200 hz: 60 dpi: 141 size: 345x215mm (13.58x8.46") diag: 407mm (16") modes: 1920x1200 API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris inactive: gbm,wayland API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.1 glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P) device-ID: 8086:a7a8 (...) $ xrandr Screen 0: minimum 320 x 200, current 1920 x 2280, maximum 16384 x 16384 eDP-1 connected primary 1920x1200+0+1080 (normal left inverted right x axis y axis) 345mm x 215mm 1920x1200 60.00*+ 60.00 1920x1080 60.00 1600x1200 60.00 (...) HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 698mm x 392mm 1920x1080 60.00*+ 50.00 59.94 30.00 25.00 24.00 29.97 23.98 1680x1050 59.88 1600x900 60.00 1280x1024 75.02 60.02 1440x900 59.90 1280x800 59.91 (...) $ LANG=C sudo lshw -class display
*-display
description: VGA compatible controller
product: Raptor Lake-P [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 mode=1920x1200 resolution=1920,1200 visual=truecolor xres=1920 yres=1200
resources: iomemory:600-5ff iomemory:400-3ff irq:177 memory:6000000000-6000ffffff memory:4000000000-400fffffff ioport:3000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
$ sudo dmesg -l err (...) i915 0000:00:02.0: [drm] *ERROR* Unclaimed access detected prior to suspending (...)
Hi javo8
Thank you for providing all the necessary details that may contribute greatly to our troubleshooting.
Kindly answer the following questions:
- What is the Driver Version of your Integrated Graphics?
- What is the make and model of the Monitor?
We look forward for your response!
Robbie R.
Hello
- Display - "Intel Corporation Raptor Lake-P [UHD Graphics] (rev 04) (prog-if 00 [VGA controller])"
Hello javo8,
Thank you for your response.
Kindly answer the additional following questions:
- What is the exact model number of the new Samsung M5 monitor?
- Can you check the system logs for any errors or warnings that occur when the monitor goes black? Please use the command dmesg | grep - i drm.
- How is the monitor configured in your display settings? Are you using any custom resolution or refresh rates?
Upon checking the BIOS of your System, it seems that it is currently outdated. I suggest having this updated to latest, kindly visit Lenovo System Update: Update Drivers, BIOS and Applications - Lenovo Support US.
Robbie R.
Hey Robbie
So.
It is this one. It says S27CM501EL on the back.
dmesg says nothing at the exact moment of the blink. But it does show this as soon as the SO is up.
$ sudo dmesg | grep -i drm
[ 0.885781] ACPI: bus type drm_connector registered
[ 0.889943] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 0.890853] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 3.609210] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 3.614089] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 3.614138] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 4.264357] i915 0000:00:02.0: [drm] VT-d active for gfx access
[ 4.277823] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[ 4.280632] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
[ 4.295243] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.20.0
[ 4.295247] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[ 4.309250] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[ 4.309601] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[ 4.309602] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[ 4.309998] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[ 4.310741] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[ 5.648459] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
[ 5.681937] fbcon: i915drmfb (fb0) is primary device
[ 5.681950] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 8354.571948] i915 0000:00:02.0: [drm] *ERROR* Unclaimed access detected prior to suspending
Nothing special. 1920x1080 @ 60 Hz, 100% scaling.
Also, I updated the BIOS as you suggested and it didn't help but it changed the output of the dmesg command.
[ 0.882530] ACPI: bus type drm_connector registered
[ 0.891076] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 0.891829] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 1.983919] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 1.988386] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.988442] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 2.777012] i915 0000:00:02.0: [drm] VT-d active for gfx access
[ 2.796961] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[ 2.800765] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc.bin (v2.20)
[ 2.817591] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.20.0
[ 2.817594] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[ 2.831304] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[ 2.831662] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[ 2.831664] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[ 2.832032] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[ 2.832910] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[ 4.182911] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
[ 4.213614] fbcon: i915drmfb (fb0) is primary device
[ 4.213617] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Hello javo8,
Thank you for providing the detailed information, including the SSU file and recent updates. It's helpful to know that you've updated the BIOS and provided the relevant logs and specifications.
- Can you provide the exact version of the i915 driver installed on your system? To acquire this, please refer to https://dgpu-docs.intel.com/Q%26A/Q%26A.html
- Have you tried adjusting the refresh rate and resolution settings in your display manager to see if it affects the issue? If so, what settings did you try, and did they have any impact?
- Are there any external devices or peripherals connected to your laptop that could potentially cause interference?
We look forward for your reply!
Robbie R.
Hello javo8,
Robbie R.
Hello javo8,
Robbie R.
This forum is sooo slow that I already had the monitor returned to the store.
