23279 Discussions
FIFA 17 on Intel HD 5500 (i5-5300U)
IGame
Game crashes at startup. Here is the error in Event Viewer:
Driver Version: 20.19.15.4531
Faulting application name: FIFA17.exe, version: 1.0.0.0, time stamp: 0x58b9d57e
Faulting module name: FIFA17.exe, version: 1.0.0.0, time stamp: 0x58b9d57e
Exception code: 0xc0000005
Fault offset: 0x0000000006bede82
Faulting process id: 0x33fc
Faulting application start time: 0x01d2ad0a06a316f7
Faulting application path: C:\Program Files (x86)\Origin Games\FIFA 17\FIFA17.exe
Faulting module path: C:\Program Files (x86)\Origin Games\FIFA 17\FIFA17.exe
Report Id: 17feff9c-d589-4d4e-aaed-2e23bebc9dbc
Faulting package full name:
Faulting package-relative application ID:
Hello intelgamer,
I understand you are trying to play FIFA 17, but it crashes at startup.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .xml file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
The error message you are getting looks like a runtime error of the application itself. If possible try reinstalling it.
Fred
Hello intelgamer,
I was wondering if you still need assistance with FIFA17. If you still need assistance please provide the Intel® System Support Utility.
Fred
