22654 Discussions
Failing to install drivers
BKilm
Hey i tried playing the new starwars beta and i get this error message popup that i have attached to the discussion. i have tried installing a new driver through the Intel utility installer but is finishes, says success then when i click finish it pops up with "failed".
I have also attached the drivers i have tried to install, also the only ones i can install through Intel Utility and they normally say failed after them.
I have tried to manually install the latest driver but it says i already have the latest driver available.
Please help and thanks.
Anonymous
Not applicable
Hi Swiper,
The latest graphics driver for Intel® HD graphics 4600 is version 10.18.14.4294 (package 15.36.26.4294) There are more available in the link below
https://downloadcenter.intel.com/product/81496 Downloads for Intel® HD Graphics 4600 for 4th Generation Intel® Core™ Processors
Verify if you are already running the latest chipset driver and BIOS version of your motherboard.
If problem continues please reply with the summary of the Intel® System Support Utility.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility
Mike C
