21291 Discussions
[Feature Request] Add FPS counter to in-game overlay
Horsemeatburger
System: HP z4G4 workstation (XEON W-2150B, 64GB 4x16GB DDR4 ECC Registered RAM, 3.84TB Kioxia CMR5 U.2 NVMe SSD, Mellanox Connect-X4 10Gbps Ethernet adapter, REBAR enabled
GPU: intel Arc A750 8GB
Arc Driver version: 31.0.101.4502
OS: Windows 11 22H2
Problem:
The in-game overlay in Arc Control shows a number of interesting GPU related parameters, however its usefulness could be increased massively by adding FPS information to the available parameter options.
Suggestion:
1. Add the following parameters to the in-game overlay options:
- (Current) FPS
- Average FPS
- Min/Max FPS
2. Add a setting to Arc Control which allows the user to define a key/shortcut for resetting the min/max/average FPS counter
IsaacQ_Intel
Hello Horsemeatburger,
Thank you for posting on the Intel®️ communities.
We appreciate your feedback. We will send your comments to the proper department for them to be aware of your remarks and to keep improving the customer's experience while using Intel products. Let us know if you have any other questions.
Isaac Q.
IsaacQ_Intel
Isaac Q.
