18915 Discussions
Four false non PNP monitors when hypervisor enabled
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Intel 4th gen hd 4600 will not work with new drivers 4501+ on Windows 10 when Hypervisor is enabled.
Effect: Causes false phantom monitors to show up in device manager and settings.
External monitor isn't detected.
Intel Graphics Control Panel will not open.
General performance issues like lag and frame rate drops.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Dell 9530 XPS
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Optimum with NV 750
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP = Sharp QHD
EFP = LG HD FHD
How much memory [RAM] in the system (see note2 below).
16GB DDR3
2 GB DDR5 VRAM
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
HDMI
Hypervisor enabled
<td style="border: 0px solid black; padding: 0 5.4pt 0 5.4pt; border-right: solid windowtext 1.0pt; border-bottom: solid windowtext 1.0pt; border-left: none; border...
Hello riksterinto,
Thank you for contacting Intel Communities.
In this case, as Ronald_Intel mentioned in /message/468783# 468783 this post, we recommend to keep using the original thread that was opened for this issue:
/thread/110642 False multiple monitors with intel drivers
Once new information/updates are available, the thread above will be updated.
JC
Hello riksterinto,
JC
Thanks. Was concerned nobody was looking at the other one since there had been no updates for about a week and it had been marked answered.
Hi riksterinto,
You are welcome.
I just checked the thread and it is marked as "Not Answered", and the last update was posted yesterday by Ronald_Intel.
Be sure that the thread in question is being checked.
Please don't hesitate in contacting us back if you need further assistance.
JC
