23092 Discussions
Frequent crash when playing FINAL FANTASY X/X-2 HD Remaster with Intel HD Graphics 5500
DDa_X
Hi, I have problems with playing FINAL FANTASY X/X-2 HD Remaster. The game itself does not require a very high-end graphic card. In fact, I can run in 30 fps (which is the highest framerate possible for the game) with a medium graphic setting in 720p. However, the game frequently crashes when scene changes or in the middle of a real-time animation. The frame just suddenly freezes and then the game crashes without giving any error message. I have tried to set all graphic options to low, the frequency may decrease a little, but the crash remains.
My laptop:
  • Windows 10 Pro build 14393.51 (The Aniversary version)
  • Intel Core i5-5300u @ 2.30GHz
  • Intel HD 5500 graphics with driver version 15.40.25.4463
  • 8 GB RAM
Is there any way to solve this problem? I also learn from the internet that many people using a Intel gpu encounter the same problem as mine. Will there be an update of the drive to solve this? Thanks.
Hello Carolos:
On the following link you will be able to find the latest version of the graphics driver for the Intel® HD Graphics 5500 controller:
Driver 4474:
https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210 https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210
What is the model of the motherboard?
What is the model of the processor?
If this is a laptop, what is the model of it?
Alberto
DDa_X
Thanks for reply.
I have tried the latest driver, however the problem remains. The model of my laptop is "X1 Carbon (Type 20BS) Laptop (ThinkPad)".
Hello Carolos:
Thank you very much for providing that information.
I was checking the specifications of the laptop, and it says that the laptop is fully compatible with Windows® 7 or 8.1, Windows® 10 it is not listed, so that might be the reason why it is not working properly, as you can confirm in here:
https://support.lenovo.com/cr/en/documents/pd100511 https://support.lenovo.com/cr/en/documents/pd100511
However, since the graphics driver 4474 did not work properly, we can try the graphics drivers from the following link, it is directly from Lenovo:
http://support.lenovo.com/cr/en/products/Laptops-and-netbooks/ThinkPad-X-Series-laptops/ThinkPad-X1-Carbon-20BS-20BT/downloads/DS103422 http://support.lenovo.com/cr/en/products/Laptops-and-netbooks/ThinkPad-X-Series-laptops/ThinkPad-X1-Carbon-20BS-20BT/downloads/DS103422
Also I found a firmware update for the monitor, we can try that driver as well:
http://support.lenovo.com/cr/en/products/Laptops-and-netbooks/ThinkPad-X-Series-laptops/ThinkPad-X1-Carbon-20BS-20BT/downloads/DS103610 http://support.lenovo.com/cr/en/products/Laptops-and-netbooks/ThinkPad-X-Series-laptops/ThinkPad-X1-Carbon-20BS-20BT/downloads/DS103610
Another option, will be to use the Inbox drivers, that get installed when you install Windows® or when you do a Windows® update.
Once you tried the options above, if the problem remains, then the best thing to do will be to get in contact with Lenovo directly to check if they have an specific driver for this problem, or any other solution.
Lenovo's phone number: 855-253-6686
Lenovo's support page: http://support.lenovo.com/ http://support.lenovo.com
Alberto
DDa_X
Thanks for that.
In fact, I have tried the driver from lenovo before, however the problem is still there. Just now I tried the driver for the monitor, but it doesn't work as well.
Also,I don't think it is a individual problem of my laptop. Many people talk about the problem on the internet, for example here: https://steamcommunity.com/app/359870/discussions/0/364042063110721720/ Preventing crashes on Intel graphics. :: FINAL FANTASY X/X-2 HD Remaster General Discussions . I think the problem is from the driver provided by intel. Can you test it at your end?
Hoping for your reply.
Hello Carolos:
Sure, we can test it, actually we will try now to replicate the issue, for us to do that, even though you already provided some information, we need to gather some more details to try to use the same components you have.
From the following chart, please try to fill as much information as you can, so we can get some details about the problem:
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issuePlease place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</td>Hardware (HW)Brand and Model of the system.Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?Make and model of any Displays that are used to see the issue (see note2 below).  LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)How much memory [RAM] in the system (see note2 below).Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etcHardware Stepping (see note1 below).Software (SW)Operating System version (see note2 below).VBIOS (video BIOS) version. This can be found in "information page" of CUI (right click on Desktop and select "Graphics Properties".<span...
DDa_X
Hello, here are the things you required.
Category
Questions
Description
Problem with running FINAL FANTASY X/X-2 HD Remaster (steam version). The game frequently crashes when the scene changes or in the middle of a real-time animation. The frame just suddenly freezes and then the game crashes without giving any error message. Also, if you do not set all graphic options to low, you cannot pass the opening scene. The crash is not that random, it occurs at specific moment, such as the opening scene.
Always (100%): X (Opening scene without setting the graphic options to low)
Often (51-99%): X (During the game)
Sporadic (20-50%):
Very Sporadic (<20%):</span>
Hardware (HW)
Laptop: Thinkpad X1 Carbon (20BS0032US)
  • CPU: Intel Core i5-5300u @ 2.30GHz
No
LFP
8GB
<p align=...
Hello Carolos:
Thank you very much for providing all those details, they will be very useful for us in order to try to replicate the issue.
As soon as I get a possible resolution for this problem, I will post that information on this thread.
Alberto
Hello Carolos:
I just wanted to let you know we are still doing the investigation on this matter in order to try to get a possible fix for this issue.
We also wanted to confirm if the problem is related to FINAL FANTASY X or FINAL FANTASY X-2, or if the problem happens on both games?
In the mean time, please try the following driver, it is version 4501, and please let us know the results:
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=80939 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=80939
If the issue persists after that, then please get into Intel® graphics control panel, select "3D" and then choose "performance".
Alberto
DDa_X
Hello Alberto:
Thanks for that. I have tried the latest driver along with setting "3D" option to "performance", but it didn't solve the issue. About FINAL FANTASY X-2, I haven't played the game yet, actually. But I test running it for a while (about 20 minutes) and I did encounter some crash as in FINAL FANTASY X. It seems that both of the games have the issue.
Hello Carolos:
Based on that, we will continue with our research in order to try to find a possible resolution for this problem.
Alberto
RonaldM_Intel
Hello Everyone,
I'll like to inform that we concluded our investigation of this issue. It was determined that the game requires 512MB of dedicated graphics memory, however, it is not handling the DVMT properly resulting in the application crash.
We reached out to the game developer to work on this but it was decided that the game won't support Intel Graphics, thus it is with regret that we are closing this issue from our side.
Ronald M.
