23272 Discussions
GTA 5 Crashes And GTA 4 very Bad Performance
Tomas4
Previously I had an Intel Core I3 10105F, 16GB Ram 3200MHz, Motherboard Asus H510M E with Intel Iris Xe DG1 or ASUS DG1-4G-SI. When I installed the Intel ARC Drivers GTA 5 has any graphic configuration, the game also crashed on its own or else when I played, it randomly crashed on its own again and most of the time I got the error err_mem_embeddedalloc_guard_1 in GTA 5 and Online. In GTA 4 the performance is very bad even if the graphics are very low the same thing works very badly. I currently have a Ryzen 5 4600G, 16GB Ram 3200MHz, Motherboard A320M R Pro Wifi and I still have the Intel Iris Xe DG1 ASUS DG1-4G-SI graphics card and unfortunately I still have the same problems with GTA 5 and 4. I tried Installing and uninstalling Drivers from the Official Page of ASUS and Intel, whether from Intel ARC or Intel Integrated Graphics, GTA 5 and 4 work very badly.
IsaacQ_Intel
Hello @Tomas4
·      Do you have any discrete GPU?
Also, please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Also let me explain you something related to your CPUs: Intel, AMD, and IRIS Xe.
Intel Core i3 10105F CPU: One notable feature of this CPU is that it doesn't come with integrated graphics. Integrated graphics are typically a part of the CPU package and provide basic graphical capabilities, allowing users to connect displays and perform tasks that involve visual elements. However, in the case of the i3 10105F, it lacks integrated graphics, which means that it relies solely on a dedicated graphics card for any graphical processing needs. This makes the i3 10105F ideal for systems where a dedicated graphics card is already in use, such as for gaming or specialized graphical workloads.
Ryzen 5 4600G CPU: AMD's Ryzen lineup of processors and is equipped with Radeon™ Graphics. This means that it comes with integrated graphics capabilities powered by Radeon technology. Integrated graphics are built into the processor and provide a level of graphical performance suitable for everyday tasks, light gaming, and multimedia consumption. The inclusion of Radeon Graphics on the Ryzen 5 4600G makes it a good choice for systems that don't require a dedicated graphics card but still need decent graphical capabilities.
Iris Xe Graphics Compatibility: Iris Xe graphics are a type of integrated graphics developed by us, they are not compatible with the Ryzen 5 4600G CPU. This is because Iris Xe graphics are specifically designed for Intel processors, and they are not interchangeable with Radeon Graphics, which are part of AMD processors like the Ryzen 5 4600G. If you were to use a Ryzen 5 4600G CPU, you would be utilizing its built-in Radeon Graphics, and you wouldn't be able to use Intel's Iris Xe graphics technology on that particular CPU.
In summary, the Intel Core i3 10105F CPU lacks integrated graphics, making it suitable for systems with dedicated graphics cards. The Ryzen 5 4600G CPU features Radeon Graphics, providing integrated graphics capabilities, and it's important to note that Iris Xe graphics are not compatible with the Ryzen 5 4600G CPU due to differences in architecture and design between Intel and AMD processors.
Isaac Q.
Tomas4
Hello, Yes, I am using ASUS Intel DG1 dedicated graphics, ASUS DG1-4G-SI and I tell you that the first time I installed this graphics card with the AMD motherboard and processor, it did not respond and it did not send an image. But later I looked closely Yes, the BIOS was configured correctly and for some reason the ASUS Intel DG1 Graphics ended up working with the AMD motherboard and processor. I don't know where to pass the .TXT file that you told me to do.
Tomas4
And for now the only driver that works well in GTA 5 without crashes is the 30.0.101.1340 of the integrated graphics. It is not the Intel ARC driver. those of Intel ARC and Current causes GTA 4 to have a bad performance and in GTA 5 it closes itself
IsaacQ_Intel
Hello @Tomas4
Thank you for your reply.
Based on our information, the "err_mem_embeddedalloc_guard_1" error in GTA 5 Online indicates issues with memory allocation for game resources. This problem can lead to crashes and freezes while playing. To address this, try restarting the game, updating your graphics drivers, and lowering graphics settings. You can also verify game files, ensure your system meets the game's requirements, and check for software conflicts. If these steps don't work, consider updating the game and reaching out to official support for further assistance.
Memory allocation in a video game like GTA 5 is crucial for managing resources such as textures, models, audio files, and other game assets. If there's a problem with memory allocation, it can lead to crashes, freezing, or other stability issues while playing the game.
Also, the TXT file must be attached to the comments in the forum. To attach a file in Intel's community forums, log in to your account, compose a post or reply, look for the attach/file icon (often a paperclip), upload your file, and insert it into your post. Preview your post, if possible, then submit it. Remember to check for file size limits and format requirements.
Once you furnish us with the TXT file, we'll need to conduct some research.
Isaac Q.
Tomas4
Hello again, I literally did everything you say, check if the game is up to date, update to the latest version of the INTEL ARC driver 31.0.101.4644, I checked if there is any conflict and there isn't, I also have to say that with the driver I mentioned I got the error ERR_GFX_D3D_INIT and I searched the internet and did everything they told me and even so gta 5 and Online kept going wrong, I increased and decreased the graphics of the game to see if it works well and in any graphics configuration it crashes in the same way and gta 4 continues to have bad performance in any graphic configuration. In the .TXT you will see that I have a previous version because in that version gta 5 works fine for me and it does not crash but in gta 4 it still works just as badly, I would like that in the next intel ARC driver update they would fix this for me, Thank you.
IsaacQ_Intel
Hello @Tomas4
Isaac Q.
IsaacQ_Intel
Hello @Tomas4
Thank you for your patience.
In this occasion we want to confirm some information first, please answer to our questions:
·        Are you using any Mods Or Addons? if so can the you try the vanilla version of both games? It seems based on gameplay.intel.com Xe GFX can run GTA V. (It seems GTA IV is not in the list, but it does not mean it won't run)
·        Please check the Recommended settings GTA V.
·        Can you change to DX10 or DX11 and see if it happens?
·        Are you using any overclocked settings?
·        Where did you buy the games from?
Isaac Q.
Tomas4
No, I don't use addons and mods because I couldn't play GTA Online. The game is Base Without mods. I had already tried those recommended graphic settings in GTA 5 and even so the game keeps crashing for me. Yes I can switch between DX 10, 10.1 and 11 but I had already tried them all and it still gives me the same problem. I can't use Overclock because the graphics doesn't allow it and I don't have anything with overclock. The games come purchased from Steam.
IsaacQ_Intel
Hello @Tomas4
We appreciate your patience as we delve into this information for additional research. We apologize for the extended time it's taking to reach a resolution, and please rest assured that we're fully committed to doing our utmost to address this situation. Thank you for your understanding.
Isaac Q.
Tomas4
okay. Thank you very much, by the way I just tried the recommended settings of what you told me to try and for a limited random time the game is paused or not, it crashes and returns to throwing me the error ERR_MEM_EMBEDDEDALLOC_GUARD_1 Game memory error. Reboot the system and reload the game. This is happening to me with the latest Intel ARC Driver 31.0.101.4644.
IsaacQ_Intel
Hello @Tomas4
We're actively engaged in ongoing research, and we're committed to keeping you informed. As soon as we gather additional information, we'll promptly reach out to you.
Isaac Q.
IsaacQ_Intel
Hello @Tomas4
Based on our information, Rockstar has confirmed that the reason Grand Theft Auto IV is no longer available to purchase from Steam is its reliance on the Games for Windows Live (GFWL) platform, which it says Microsoft is “no longer supporting.
However, we will try to replicate the issue on our lab to find a possible solution to your issue on GTA5.
Isaac Q.
IsaacQ_Intel
Hello Tomas4
We sincerely regret the delay in completing this laboratory work, but please rest assured that our team is actively engaged in its progress. We will promptly provide you with the results as soon as they become available. We greatly appreciate your patience and understanding. Thank you.
Isaac Q.
IsaacQ_Intel
Hello Tomas4
Based on our extensive laboratory testing, we were unable to replicate the reported issue. In fact, there were no crashes whatsoever while running GTA V. Therefore, it might be advisable to reach out to the game's developer for further assistance, as our experience differs from the reported problem.
Regarding GTA IV, we regret to inform you that we were unable to run the game due to Rockstar's confirmation that Grand Theft Auto IV is no longer available for purchase on Steam. This unavailability is attributed to its reliance on the Games for Windows Live (GFWL) platform, which Microsoft has ceased to support.
Given that this issue is ultimately linked to the game developer's decisions and external factors, we will consider this matter closed if there are no further inquiries. Should you require additional information or have any more questions, kindly submit a new query, as this particular thread will no longer be actively monitored.
Isaac Q.
IsaacQ_Intel
Hello Tomas4
We hope you are doing fine.
Best regards.
Isaac Q.
