21697 Discussions
GTA San Andreas not opening
AbhishekKumarUYG
After updating Drivers, GTA San Andreas not opening.
In earlier version of Driver, we could add custom display resolution, but not now.
Please add an option to add custom resolution.
DeividA_Intel
Hello AbhishekKumarUYG,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your game due to this error.
1. Just to confirm, you have 2 issues, right? 1) Can't open GTA San Andreas. 2) Can add custom resolution.
2. Are you trying to add custom resolution using the Intel® Graphics Command Center? Or, are you trying with other apps?
3. Is this issue present with other games?
4. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
AbhishekKumarUYG
1. I can't be able to add Custom resolution (800*600*32), as result GTA San Andreas not opening. Because GTA San Andreas require this specific resolution to run.
2. Yes, I tried adding custom resolution using Intel® Graphics Command Center and Intel® Graphics Command Center BETA. In Intel® Graphics Command Center, there's no option to add custom resolution. And in Intel® Graphics Command Center Beta, it says "Custom Resolution is not supported on Internal Displays." Check attached screenshot.
3. No, all other games are running.
4. I ran Intel® System Support Utility (Intel® SSU) and attached the report.
Jose_Intel
Thank you for your reply.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it. You may also find the Discontinued Products website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Jose B.
