22259 Discussions
Games Crashes When I Use FSR 3 Frame Rendering With My ARC A770 GPU
aytxx24
So far in Cyberpunk 2077 and Ratchet & Clank Rift Apart, the games crash when I turn on fsr 3 frame rendering. When I turn it off, there is no problem. I would like this problem, which is probably driver related, to be solved immediately. I left Cyberpunk's error logs. I don't want to play with FSR 3 turned off because it doubled my fps. I have Intel ARC A770 Limited Edition GPU and my drivers are up to date.
ArchieD_Intel
Hi aytxx24,
  • Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
  • When did the issue start? Was it after a specific driver update or game patch?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Have you tried adjusting the graphics settings?
  • Could you provide a screenshot of your in-game display and graphics settings?
  • Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi aytxx24,
Archie D.
ArchieD_Intel
Hi aytxx24,
Archie D.
