20951 Discussions
Geçersiz yapılandırma verileri
onur2
İntel sürücü ve destek asistanı sayfasına girdiğimde geçersiz yapılandırma verileri hatası ile karşılaşıyorum.
Jocelyn_Intel
Hello, @onur2
Thank you for posting on the Intel® communities.
Please be informed that I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
  • Is it possible for you to send that screenshot in English so we can understand the error message? If not, please specify the error message itself.
  • What Intel Product do you have that you are trying to update?
Please be aware that Intel® Driver & Support Assistant was designed for Intel products, such as Intel® NUCs, that are manufactured by Intel. If you have a third-party system (laptop, desktop PC, mini PC), we recommend you to use the Driver assistants provided by your System Manufacturer and use their driver software, to avoid potential installation incompatibilities.
Jocelyn M.
emirhan79
Aynı sorun benim bilgisayarımdada var. İntel driver and support assistant sitesinden güncellemeleri alamıyorum.
Jocelyn_Intel
Hello, @onur2
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Jocelyn_Intel
Hello, @emirhan79
Thank you for the information provided, however, as previously mentioned, I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
Please read carefully the information below and provide the following information so we can understand and help you out:
Please be aware that Intel® Driver & Support Assistant was designed for Intel products, such as Intel® NUCs, that are manufactured by Intel. If you have a third-party system (laptop, desktop PC, mini PC), we recommend you use the Driver assistants provided by your System Manufacturer and use their driver software, to avoid potential installation incompatibilities.
Jocelyn M.
Jocelyn_Intel
Hello, everyone.
As we have not heard back from you, we will proceed to close this thread now. If you need any additional assistance with other matters in the meantime, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
