22216 Discussions
Graphic Card: intel® nuc kits nuc12dcmi9
JesusN
Hey, I want to check what kind of Graphic Cards my Nuc can support, I have the following ones that I saw on Amazon:
- ZOTAC Gaming GeForce RTX™ 3060 Ti Twin Edge OC LHR 8GB GDDR6 256-bit 14 Gbps PCIE 4.0 Graphics Card
- MSI Gaming GeForce RTX 3060 12GB 15 Gbps GDRR6 192-Bit HDMI/DP PCIe 4 Torx Twin Fan Ampere OC
I would appreciate more guidance regarding which ones can be installed on my Nuc since the ones you had in the PDF are too specific and can't be found on Amazon. https://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20NUC&prdName=NUC12DCMi9
Alberto_R_Intel
JesusN, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order for us to try to provide the most accurate response to your inquiry, I will do further research on this matter. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello JesusN, I just received an update on this matter.
These are some examples of graphics cards listed in our Intel® compatibility tool that will work with your Intel® NUC and that are available on Amazon:
ASUS* AMD Radeon RX 5700 XT 8G:
https://www.amazon.com/Radeon-Installed-Triple-Model-ROG-STRIX-RX5700XT-O8G-GAMING/dp/B07XC5CQDK
EVGA GeForce RTX 3060 Ti XC GAMING:
https://www.amazon.com/EVGA-GeForce-Gaming-08G-P5-3667-KR-Cooling/dp/B08P2H5LW2
Gigabyte GeForce RTX™ 2080 Ti TURBO 11G"
https://www.amazon.com/GIGABYTE-rev-2-0-Graphics-GV-N208TTURBO/dp/B083DT8Q9L
Intel® Arc A770:
https://www.amazon.com/Intel-A770-Limited-Express-Graphics/dp/B0BJK3V3P4
Albert R.
n_scott_pearson
Albert,
Where is the data regarding fit? What are the height, width and depth restrictions? What is max. power available to a card? I couldn't find this data and would love a pointer to it.
n_scott_pearson
BTW, I would love to see this information presented in a table and covering the 11th, 12th and 13th generation Extreme NUCs.
Alberto_R_Intel
JesusN, You are very welcome. Thank you very much for your response.
Sure, I will check those parts to try to confirm if they are compatible with your Intel® NUC and provide a response as soon as possible.
Albert R.
Alberto_R_Intel
After checking the links, we would like to let you know that the graphics cards validated in the compatibility tool are the ones we can guarantee are going to work. If the GPU is not listed, it does not mean is not compatible but we cannot guarantee compatibility.
You can also check with the manufacturer of the graphics card to verify if they have further details about the compatibility with the Intel® NUC.
Albert R.
