- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I am new in this forum and hope for some advice to solve my problem with onboard-graphics-resolution on a LINUX Mint 21.2 Cinnamon-system. Please pardon my English, mother tongue is German.
Currently a motherboard 'MSI B250M PRO-VDH' (MS7A70) with onboard graphics 'Intel® HD Graphics 530' GPU Skylake GT2 is installed in my PC.
Under Windows everything works fine, resolution is 1600x900 (monitor AOC 24G2W1G4). GPU-Z-result attatched. Unfortunately, this is not the case with LINUX MINT Cinnamon 21.2. The monitor is recognized, but not all resolutions are offered. I would like to continue to use 1600x900, but only 1920x1080, 1280x720 and below are available under Settings -> Screen.
"xrandr" also does not display 1600x900 resolution. "sudo apt install xserver-xorg-video-intel" returns that the driver is up to date.
On the Intel website I can only find drivers for Windows, also at MSI I will not find what I am looking for with regard to LINUX/UBUNTU. Changing Kernel to 5.15 didn´t take effekt. At my request in the LinuxMintUsers forum, I have not received a solution to this particular problem.
Don´t know, if it is helpful, but here is the result of inxi -Fzr:
doc264@doc264-MS-7A70:~$ sudo inxi -Fzr
[sudo] Passwort für doc264:
System:
Kernel: 6.5.0-1007-oem x86_64 bits: 64 Desktop: Cinnamon 5.8.4
Distro: Linux Mint 21.2 Victoria
Machine:
Type: Desktop System: MSI product: MS-7A70 v: 2.0 serial: N/A
Mobo: MSI model: B250M PRO-VDH (MS-7A70) v: 2.0 serial: <filter>
UEFI: American Megatrends v: A.30 date: 04/06/2017
CPU:
Info: quad core model: Intel Core i5-6400 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 800 min/max: 800/3300 cores: 1: 800 2: 800 3: 800
4: 800
Graphics:
Device-1: Intel HD Graphics 530 driver: i915 v: kernel
Display: server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2)
v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1
Audio:
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k6.5.0-1007-oem running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb
Report: hciconfig ID: hci0 state: up address: <filter> bt-v: 2.1
Drives:
Local Storage: total: 24.16 TiB used: 2.92 TiB (12.1%)
ID-1: /dev/sda vendor: Seagate model: BarraCuda 120 SSD ZA500CM10003
ID-2: /dev/sdb vendor: Seagate model: ST6000VN001-2BB186 size: 5.46 TiB
ID-3: /dev/sdc vendor: Seagate model: ST6000DM003-2CY186 size: 5.46 TiB
ID-4: /dev/sdd type: USB vendor: Toshiba model: External USB 3.0
ID-5: /dev/sde type: USB vendor: SanDisk model: Ultra size: 57.3 GiB
ID-6: /dev/sdk type: USB vendor: Western Digital model: WD Elements 25A3
Partition:
ID-1: / size: 456.89 GiB used: 37.54 GiB (8.2%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Repos:
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http://packages.linuxmint.com victoria main upstream import backport
2: deb http://archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http://archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http://archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http://security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Active apt repos in: /etc/apt/sources.list.d/vivaldi.list
1: deb [arch=amd64] https://repo.vivaldi.com/stable/deb/ stable main
Info:
Processes: 237 Uptime: 1m Memory: 62.56 GiB used: 1.54 GiB (2.5%)
Shell: Sudo inxi: 3.3.13
Can you please tell me what I have to do to set the desired resolution of 1600x900 in LINUX?
Many thanks and kind regards
Doc
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello @doc264
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it. You may also find the Discontinued Products website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Jose B.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
hi,
I've got the same problem on Linux Mint. Did you find the solution?
a,
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
unfortunately noone had helpful idea how to add resolutions like 1600 x 900 px , neither here nor in 'LinuxMintUsers'-Forum, sorry.
If you are more successful, please let me know.
Best regards
Doc
