23100 Discussions
Graphics Driver for Intel N2805 Windows 8.1 32 Bits
YPira
I can't find drivers for an Intel N2805 processor with Windows 8.1 32 bits, the driver stopped working after installing 8.1, and the Download Center only shows the driver for 8/8.1 64 bits and for 32 bits only 8, so Im stuck with Microsoft basic screen driver, should I try installing the 8.1 for 64 bits? Because the detection utility won't find nothing, I really need the drivers because even the mouse is laggy...
Kevin_M_Intel
Hi SomeoneMeh,
I am sorry you are having problems installing the driver but let me help you with this.
Based on the information you have provided, I recommend you doing the following steps:
  1. Uninstall the current driver. Here you have some instructions:
http://www.intel.com/support/graphics/sb/CS-034574.htm http://www.intel.com/support/graphics/sb/CS-034574.htm
  1. Download the latest driver for your graphics controller at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714
If you get a notification message during the installation, it indicates that your computer manufacturer does not allow the installation of generic Intel video drives. You are required to install drivers from your computer manufacturer.
You may try to force the installation of Intel generic drivers by performing manual procedure, see here for instructions:
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
Here is the zip version of the video driver:
It is important to say that if the device came with a different Operating System, going back to the original Operating System is the best step to take since installing another one, the product can lose special features.
Kevin_M_Intel
Hi SomeoneMeh,
YPira
Well the I think the link you provided me was for 64 bit too, but I found the same generic file for 32 bit, and N2805 was listed for 8.1, so it worked, thanks a lot.
