I am using a laptop and it is not connected to any external display but it often goes to a black screen and sometimes a black screen on startup.
If i press F5 i can switch back to primary display.
The display adadpters listed in Device Manager are -
Intel HD Graphics 4000
Nvidia Geforce GT 650M
- Tags:
- Switches
Hello, ds123:
I would like to gather some information in order to address this matter, so please download the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility, and attach it, with this report I will be able to confirm some of that information.
Amy.
Not done it for a while, i suspect it was overheating but not certain.
Here is the file.
https://1drv.ms/u/s!AlQfM_eehl0vh3K5r_92EaoHiq0l https://1drv.ms/u/s!AlQfM_eehl0vh3K5r_92EaoHiq0l
Thank you for the report.
Please try the following suggestions;
- Update the NVIDIA GeForce GT 650M driver; http://www.geforce.com/drivers/results/103911 http://www.geforce.com/drivers/results/103911
- Update the Intel® HD Graphics driver; https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-%3Fproduct%3D81499 https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81499. with this one follow this method for the installation http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html
- Try resting your BIOS configuration to default.
Amy.
Hi, ds123:
Just wanted to check if you were able to proceed with the recommendation above, also if they worked for your inquiry.
Please le us know.
Esteban C
With Regards to your suggestions -
- Update the NVIDIA GeForce GT 650M driver - I need to use the older drivers for a specific game to work correctly.
- Update the Intel® HD Graphics driver - I am using new drivers already.
- Try resting your BIOS configuration to default - The BIOS is the newest version.
Only occasionally does it switch now, and i can press F5 to switch back displays.
Just to let you know display is still switching/going black and nothing happens when i roll back driver and if i try to install a different driver version i get the message 'Windows cannot driver at this time'.
According to your system report, you have .2653 version and the latest from our end is the .4425(https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81499 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33]). For testing purposes, can you try installing a different version of the NVIDIA GeForce GT 650M driver? By setting your BIOS to default I meant loading the default configuration, normally is done by pressing F9 once you have entered the BIOS.
Amy.
As i said earlier No new drivers will install, and i tried the latest Nvidia Driver and i get the 'Installation Failed' message.
I also reset BIOS configuration.
There is one more method worth a try, see the attachment for the steps.
Amy.
I got the latest Intel Driver installed using above method.
I will see how it goes though i did not mention as well as overheating i had a loose LCD cable which i though might have been the problem before.
I am glad to hear that you were able to install the driver, test it and let me know how it goes.
Amy.
Display still goes black every so often, i updated the driver so am thinking it is a hardware problem (LCD panel to logic board).
It is a possibility, is there any chance you can test with a different LCD panel?
Amy.
If it was the panel, would it not just switch off completely? I took it to a repair shop and they said the cable was loose but it is doing it again.
Well yeah, it could be possible.
Does this "I am using a laptop and it is not connected to any external display but it often goes to a black screen and sometimes a black screen on startup. If i press F5 i can switch back to primary display." persist?
Amy.
Hello, ds123:
How is your system behaving? Does the issue persist?
Amy.
Yes, yesterday screen was goind black every 5 seconds and starting again as i type, i have sent for a new LCD. If it still happens must be the data cable from motherboard.
I believe this could be hardware issue, so if you get the new LCD let me know how it goes.
Amy.
