20602 Discussions
Tremayne
So I was trying to update my graphics drivers through the driver manger or whatever, and not my screen is small, the resolution is fixed so I can’t change it, and my computer runs slower. I tried rolling it back to get my driver I had before but it won’t let me it’s grayed out. Idk how to fix this, when I click update drivers it says I have the latest one for my device
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Tremayne
Tremayne
@AlHill
it wasnt letting me attach the file so this is the contents of the file.
# SSU Scan Information Scan Info: Version:"2.5.0.15" Date:"02/08/2021" Time:"00:00:41.3054115" # Scanned Hardware Computer: BaseBoard Manufacturer:"Hewlett-Packard" BIOS Mode:"Legacy" BIOS Version/Date:"Hewlett-Packard 786G7 v01.02 , 10/22/2009 12:00 AM" CD or DVD:"hp DV-W28S-VS" Embedded Controller Version:"255.255" Platform Role:"Desktop" Processor:"Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz , GenuineIntel" Secure Boot State:"Not Available" SMBIOS Version:"2.6" Sound Card:"High Definition Audio Device" System Manufacturer:"Hewlett-Packard" System Model:"HP Compaq 8000 Elite USDT PC" System SKU:"BM737US#ABA" System Type:"X86-based PC" - "Display" Intel ® Graphics Driver Version:"Not Available" - "Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)" Adapter Compatibility:"Intel Corporation" Adapter DAC Type:"Not Available" Adapter RAM:"Not Available" Availability:"Running or Full Power" Bits Per Pixel:"32" - "Caption":"Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)" Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Q45%2fQ43+Express+Chipset+(Microsoft+Corporation+++WDDM+1.1)" CoInstallers:"oem4.inf,iEGL0,Not Available,Not Available" Color Table Entries:"4294967296" Dedicated Video Memory:"Not Available" Driver:"igdkmd32.sys" Driver Date:"03/10/2013 05:00 PM" Driver Path:"C:\WINDOWS\system32\DRIVERS\igdkmd32.sys" Driver Provider:"Intel Corporation" Driver Version:"8.15.10.2702" INF:"oem4.inf" INF Section:"iEGL0" Install Date:"Not Available" Installed Drivers:"igdumd32.dll,igd10umd32.dll,igd10umd32.dll" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Last Reset:"Not Available" Location:"PCI bus 0, device 2, function 0" Manufacturer:"Intel Corporation" Microsoft DirectX* Version:"DirectX 12" Monochrome:"No" Number of Colors:"4294967296" Number of Video Pages:"Not Available" PNP Device ID:"PCI\VEN_8086&DEV_2E12&SUBSYS_3648103C&REV_03\3&B1BFB68&0&10" Power Management Capabilities:"Not Available" Power Management Supported:"Not Available" Refresh Rate - Current:"64 Hz" Refresh Rate - Maximum:"64 Hz" Refresh Rate - Minimum:"64 Hz" Resolution:"800 X 600" Scan Mode:"Noninterlaced" Service Name:"igfx" Status:"Error" Video Architecture:"VGA" Video Memory:"Unknown" Video Processor:"Not Available" - "Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)" Adapter Compatibility:"Intel Corporation" Adapter DAC Type:"Not Available" Adapter RAM:"Not Available" Availability:"Offline" Bits Per Pixel:"Not Available" - "Caption":"Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)" Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Q45%2fQ43+Express+Chipset+(Microsoft+Corporation+++WDDM+1.1)" CoInstallers:"oem4.inf,iEGL1,Not Available,Not Available" Color Table Entries:"Not Available" Dedicated Video Memory:"Not Available" Driver:"igdkmd32.sys" Driver Date:"03/10/2013 05:00 PM" Driver Path:"C:\WINDOWS\system32\DRIVERS\igdkmd32.sys" Driver Provider:"Intel Corporation" Driver Version:"8.15.10.2702" INF:"oem4.inf" INF Section:"iEGL1" Install Date:"Not Available" Installed Drivers:"igdumd32.dll,igd10umd32.dll,igd10umd32.dll" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Last Reset:"Not Available" Location:"PCI bus 0, device 2, function 1" Manufacturer:"Intel Corporation" Microsoft DirectX* Version:"DirectX 12" Monochrome:"No" Number of Colors:"Not Available" Number of Video Pages:"Not Available" PNP Device ID:"PCI\VEN_8086&DEV_2E13&SUBSYS_3648103C&REV_03\3&B1BFB68&0&11" Power Management Capabilities:"Not Available" Power Management Supported:"Not Available" Refresh Rate - Current:"Not Available" Refresh Rate - Maximum:"Not Available" Refresh Rate - Minimum:"Not Available" Resolution:"Not Available" Scan Mode:"Not Available" Service Name:"igfx" Status:"OK" Video Architecture:"VGA" Video Memory:"Unknown" Video Processor:"Not Available" - "Memory" Physical Memory (Available):"1.61 GB" Physical Memory (Installed):"4.00 GB" Physical Memory (Total):"3.46 GB" - "SYSTEM ROM" Capacity:"0.00 GB" Channel:"SYSTEM ROM" Configured Clock Speed:"Not Available" Configured Voltage:"Not Available" Data Width:"2 bits" Form Factor:"Unknown" Interleave Position:"Noninterleaved" Manufacturer:"Not Available" Maximum Voltage:"Not Available" Memory Type:"Flash11" Minimum Voltage:"Not Available" Part Number:"Not Available" Serial Number:"Not Available" Status:"Not Available" Type:"Nonvolatile" - "XMM1" Capacity:"2 GB" Channel:"XMM1" Configured Clock Speed:"Not Available" Configured Voltage:"Not Available" Data Width:"64 bits" Form Factor:"DIMM" Interleave Position:"Second position" Manufacturer:"JEDEC ID:80 AD" Maximum Voltage:"Not Available" Memory Type:"DDR3" Minimum Voltage:"Not Available" Part Number:"HMT125S6TFR8C-H9" Serial Number:"DE64202C" Status:"Not Available" Type:"Synchronous" - "XMM3" Capacity:"2 GB" Channel:"XMM3" Configured Clock Speed:"Not Available" Configured Voltage:"Not Available" Data Width:"64 bits" Form Factor:"DIMM" Interleave Position:"Not Available" Manufacturer:"JEDEC ID:80 AD" Maximum Voltage:"Not Available" Memory Type:"DDR3" Minimum Voltage:"Not Available" Part Number:"HMT125S6TFR8C-H9" Serial Number:"5165602C" Status:"Not Available" Type:"Synchronous" - "Motherboard" Availability:"Running or Full Power" BIOS:"Default System BIOS, HPQOEM - 20091022" Caption:"Motherboard" - "Chipset":"Intel(R) Q45/Q43 Express" Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Q45%2fQ43+Express" Date:"10/21/2009 05:00 PM" Install Date:"Not Available" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Manufacturer:"Hewlett-Packard" Model:"Not Available" Part Number:"Not Available" PNP Device ID:"ACPI\PNP0C01\2&DABA3FF&0" Power Management Capabilities:"Not Available" Power Management Supported:"Not Available" Product:"3648h" Serial Number:"2UA01003V6" Status:"OK" Version:"Not Available" - "Networking" Intel ® Network Connections Install Options:"Not Available" Intel ® Network Connections Version:"Not Available" Intel ® PROSet/Wireless Software Version:"Not Available" - "AnchorFree TAP-Windows Adapter V9" Availability:"Running or Full Power" Caption:"AnchorFree TAP-Windows Adapter V9" CoInstallers:"Not Available" Default IP Gateway:"Not Available" DHCP Enabled:"Yes" DHCP Lease Expires:"Not Available" DHCP Lease Obtained:"Not Available" DHCP Server:"Not Available" Driver:"aftap0901.sys" Driver Date:"11/10/2017 12:00 AM" Driver Path:"C:\WINDOWS\system32\drivers\aftap0901.sys" Driver Provider:"AnchorFree TAP-Windows Provider V9" Driver Version:"19.24.12.240" Index:"0001" INF:"oem9.inf" INF Section:"aftap0901.ndi" Install Date:"Not Available" Installed:"Yes" IP Address:"Not Available" IP Subnet:"Not Available" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Last Reset:"02/07/2021 01:18 AM" Location:"Not Available" MAC Address:"00:FF:6D:25:74:C4" Manufacturer:"AnchorFree TAP-Windows Provider V9" Media Type: Net Connection ID:"Ethernet 2" NetCfgInstanceId:"{6D2574C4-B793-4C6F-BDB5-056FC2FAD806}" Number of VLANs:"0" PNP Device ID:"ROOT\NET\0000" Port:"Not Available" Power Management (Low Power):"Not Available" Power Management (Wake On LAN):"Not Available" Power Management (Wake on Magic Packet):"Not Available" Power Management Capabilities:"Not Available" Power Management Supported:"No" Product Type:"AnchorFree TAP-Windows Adapter V9" Service Name:"aftap0901" Status:"Enabled" Team Name:"Not in a team" Temperature: Type:"Ethernet 802.3" - "Service Bindings" Client for Microsoft Networks: File and Printer Sharing for Microsoft Networks: Internet Protocol Version 4 (TCP/IPv4): Internet Protocol Version 6 (TCP/IPv6): Link-Layer Topology Discovery Mapper I/O Driver: Link-Layer Topology Discovery Responder: Microsoft LLDP Protocol Driver: QoS Packet Scheduler: - "Settings" AllowNonAdmin:Non-Admin Access:"Allowed (1)" MediaStatus:Media Status:"Application Controlled (0)" MTU:MTU:"1500 (1500)" - "Intel(R) 82567LM-3 Gigabit Network Connection" Availability:"Running or Full Power" - "Caption":"Intel(R) 82567LM-3 Gigabit Network Connection" Link:"http://www.intel.com/content/www/us/en/search.html?keyword=82567LM+3+Gigabit+Network+Connection" CoInstallers:"Not Available" Default IP Gateway:"Not Available" DHCP Enabled:"Yes" DHCP Lease Expires:"Not Available" DHCP Lease Obtained:"Not Available" DHCP Server:"Not Available" Driver:"e1i6532.sys" Driver Date:"06/11/2018 12:00 AM" Driver Path:"C:\WINDOWS\system32\drivers\e1i6532.sys" Driver Provider:"Microsoft" Driver Version:"12.17.10.8" ETrackID:"Not Available" Index:"0002" INF:"net1i32.inf" INF Section:"E10DE.10.0.1" Install Date:"Not Available" Installed:"Yes" IP Address:"Not Available" IP Subnet:"Not Available" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Last Reset:"02/07/2021 01:18 AM" Location:"PCI bus 0, device 25, function 0" MAC Address:"18:A9:05:EF:8E:9D" Manufacturer:"Intel Corporation" Media Type: Net Connection ID:"Ethernet" NetCfgInstanceId:"{4CCFB616-0681-4A46-B2ED-8AFC9A461C71}" Number of VLANs:"0" NVM Version:"Not Available" Part Number:"FFFFFF-0FF" PNP Device ID:"PCI\VEN_8086&DEV_10DE&SUBSYS_3648103C&REV_02\3&B1BFB68&0&C8" Port:"Not Available" Power Management (Low Power):"Not Available" Power Management (Wake On LAN):"Not Available" Power Management (Wake on Magic Packet):"Not Available" Power Management Capabilities:"Not Available" Power Management Supported:"No" Product Type:"Intel(R) 82567LM-3 Gigabit Network Connection" Service Name:"e1i6532" Status:"Enabled" Team Name:"Not in a team" Temperature: Type:"Ethernet 802.3" - "Service Bindings" Client for Microsoft Networks: File and Printer Sharing for Microsoft Networks: Internet Protocol Version 4 (TCP/IPv4): Internet Protocol Version 6 (TCP/IPv6): Link-Layer Topology Discovery Mapper I/O Driver: Link-Layer Topology Discovery Responder: Microsoft LLDP Protocol Driver: QoS Packet Scheduler: - "Settings" *FlowControl:Flow Control:"Rx & Tx Enabled (3)" *InterruptModeration:Interrupt Moderation:"Enabled (1)" *IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)" *JumboPacket:Jumbo Packet:"Disabled (1514)" *LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)" *LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)" *NumRssQueues:Maximum Number of RSS Queues:"2 Queues (2)" *PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)" *ReceiveBuffers:Receive Buffers:"256 (256)" *RSS:Receive Side Scaling:"Enabled (1)" *SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)" *TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)" *TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)" *TransmitBuffers:Transmit Buffers:"512 (512)" *UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)" *UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)" AdaptiveIFS:Adaptive Inter-Frame Spacing:"Disabled (0)" ITR:Interrupt Moderation Rate:"Adaptive (65535)" LogLinkStateEvent:Log Link State Event:"Enabled (51)" MasterSlave:Gigabit Master Slave Mode:"Auto Detect (0)" WaitAutoNegComplete:Wait for Link:"Auto Detect (2)" - "NETGEAR WNA3100 N300 Wireless USB Adapter" Access Point:"6c:b0:ce:be:17:12" Authentication:"WPA2-Personal" Availability:"Running or Full Power" Caption:"NETGEAR WNA3100 N300 Wireless USB Adapter" Channel:"1" Cipher:"CCMP" CoInstallers:"WdfCoInstaller01005.dll,WdfCoInstaller" Connection Mode:"Auto Connect" Default IP Gateway:"192.168.1.1" DHCP Enabled:"Yes" DHCP Lease Expires:"02/09/2021 05:08 PM" DHCP Lease Obtained:"02/08/2021 05:08 PM" DHCP Server:"192.168.1.1" Driver:"bcmwlhigh6.sys" Driver Date:"03/30/2011 12:00 AM" Driver Path:"C:\WINDOWS\system32\DRIVERS\bcmwlhigh6.sys" Driver Provider:"Netgear" Driver Version:"5.100.243.6" Index:"0004" INF:"oem3.inf" INF Section:"BCM43XNMD_NT61" Install Date:"Not Available" Installed:"Yes" IP Address:"192.168.1.17;fe80::c850:6c18:678b:e522" IP Subnet:"255.255.255.0;64" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Last Reset:"02/07/2021 01:18 AM" Location:"Port_#0001.Hub_#0004" MAC Address:"2C:B0:5D:76:B8:18" Manufacturer:"Netgear" Media Type: Net Connection ID:"Wi-Fi" NetCfgInstanceId:"{2BBAB392-959A-4794-A46E-630F4FD80D57}" Network Name:"MyCharterWiFi12-2G" Network Type:"Infrastructure" Number of VLANs:"0" PNP Device ID:"USB\VID_0846&PID_9020\113" Port:"Not Available" Power Management (Low Power):"Active: Yes, Enable: Yes" Power Management (Wake On LAN):"Not Available" Power Management (Wake on Magic Packet):"Not Available" Power Management Capabilities:"Not Available" Power Management Supported:"No" Product Type:"NETGEAR WNA3100 N300 Wireless USB Adapter" Profile:"MyCharterWiFi12-2G" Radio Type:"802.11n" Receive Rate:"144 Mbps" Service Name:"BCMH43XX" Signal Strength:"89%" State:"connected" Status:"Enabled" Team Name:"Not in a team" Temperature: Transmit Rate:"19.5 Mbps" Type:"Ethernet 802.3" - "Service Bindings" Client for Microsoft Networks: File and Printer Sharing for Microsoft Networks: Internet Protocol Version 4 (TCP/IPv4): Internet Protocol Version 6 (TCP/IPv6): Link-Layer Topology Discovery Mapper I/O Driver: Link-Layer Topology Discovery Responder: Microsoft LLDP Protocol Driver: QoS Packet Scheduler: - "Settings" *PriorityVLANTag:Priority & VLAN:"Priority & VLAN Disabled (0)" 11HNetworks:802.11h+d:"Loose 11h (1)" 11NPreamble:802.11n Preamble:"Auto (-1)" Afterburner:Afterburner:"Disabled (0)" antdiv:Antenna Diversity:"Auto (-1)" ApCompatMode:AP Compatibility Mode:"Higher Performance (0)" AssocRoamPref:Association Roam Preference:"Disabled (0)" band:Disable Bands:"None (0)" BandPref:Band Preference:"None (0)" BandwidthCap:Bandwidth Capability:"11a/b/g:20/40MHz (1)" BtAmp:BT-AMP:"Enabled (1)" BTCoexist:Bluetooth Collaboration:"Auto (3)" Chanspec:WZC IBSS Channel Number:"11(20MHz) (11)" frag:Fragmentation Threshold:"2346 (2346)" FrameBursting:XPress (TM) Technology:"Disabled (0)" IBSSGProtection:IBSS 54g(tm) Protection Mode:"Auto (2)" IBSSMode:IBSS Mode:"802.11a/b Only (0)" Intolerant:40MHz Intolerant:"Disabled (0)" LOM:Disable Upon Wired Connect:"Disabled (0)" MixedCell:Mixed Cell Support:"Disabled (0)" MPC:Minimum Power Consumption:"Enabled (1)" OBSSCoex:20/40 Coexistance:"Auto (-1)" PLCPHeader:BSS PLCP Header:"Auto (Short/Long) (0)" PwrOut:Power Output:"100% (100)" Rate:Rate (802.11b/g):"Best Rate (0)" RateA:Rate (802.11a):"Best Rate (0)" RoamDelta:Roam Tendency:"Auto (3)" RoamTrigger:Roaming Decision:"Auto (3)" rts:RTS Threshold:"2347 (2347)" ShortGI:Short GI:"Auto (-1)" WakeUpCapabilities:Wake-Up Mode:"Magic & WakeUp Frame (3)" WME:WMM:"Auto (-1)" - "TAP-Windows Adapter V9" Availability:"Running or Full Power" Caption:"TAP-Windows Adapter V9" CoInstallers:"Not Available" Default IP Gateway:"Not Available" DHCP Enabled:"Yes" DHCP Lease Expires:"Not Available" DHCP Lease Obtained:"Not Available" DHCP Server:"Not Available" Driver:"tap0901.sys" Driver Date:"04/21/2016 12:00 AM" Driver Path:"C:\WINDOWS\system32\drivers\tap0901.sys" Driver Provider:"TAP-Windows Provider V9" Driver Version:"9.0.0.21" Index:"0003" INF:"oem2.inf" INF Section:"tap0901.ndi" Install Date:"Not Available" Installed:"Yes" IP Address:"Not Available" IP Subnet:"Not Available" Last Error Code:"Not Available" Last Error Code Description:"Not Available" Last Reset:"02/07/2021 01:18 AM" Location:"Not Available" MAC Address:"00:FF:0B:4A:57:90" Manufacturer:"TAP-Windows Provider V9" Media Type: Net Connection ID:"Ethernet 3" NetCfgInstanceId:"{0B4A5790-FA7A-4715-8D87-678E21B3E01B}" Number of VLANs:"0" PNP Device ID:"ROOT\NET\0001" Port:"Not Available" Power Management (Low Power):"Not Available" Power Management (Wake On LAN):"Not Available" Power Management (Wake on Magic Packet):"Not Available" Power Management Capabilities:"Not Available" Power Management Supported:"No" Product Type:"TAP-Windows Adapter V9" Service Name:"tap0901" Status:"Enabled" Team Name:"Not in a team" Temperature: Type:"Ethernet 802.3" - "Service Bindings" Client for Microsoft Networks: File and Printer Sharing for Microsoft Networks: Internet Protocol Version 4 (TCP/IPv4): Internet Protocol Version 6 (TCP/IPv6): Link-Layer Topology Discovery Mapper I/O Driver: Link-Layer Topology Discovery Responder: Microsoft LLDP Protocol Driver: QoS Packet Scheduler: - "Settings" AllowNonAdmin:Non-Admin Access:"Allowed (1)" MediaStatus:Media Status:"Application Controlled (0)" MTU:MTU:"1500 (1500)" - "Operating System" .Net Framework Version:"2.0,3.0,3.5,4.0,4.8" Boot Device:"\Device\HarddiskVolume1" Locale:"United States" OS Manufacturer:"Microsoft Corporation" OS Name:"Microsoft Windows 10 Pro" Other OS Description:"Not Available" Page File:"C:\pagefile.sys" Page File Space:"1.51 GB" Physical Memory (Available):"1.62 GB" Physical Memory (Installed):"4.00 GB" Physical Memory (Total):"3.46 GB" System Directory:"C:\WINDOWS\system32" Version:"10.0.18363 Build 18363" Virtual Memory (Available):"3.13 GB" Virtual Memory (Total):"4.97 GB" Windows Directory:"C:\WINDOWS" - "Installed Updates" KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]" KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]" KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]" KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]" KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]" KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]" KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]" KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]" KB4517245:"Update [8/29/2020]" KB4561600:"Security Update [9/7/2020]" KB4569073:"Security Update [8/29/2020]" KB4580325:"Security Update [2/2/2021]" KB4598229:"Security Update [2/2/2021]" KB4598301:"Update [2/7/2021]" KB4598479:"Security Update [2/2/2021]" - "Processor" - "Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz" Architecture:"x64" ATPO:"Not Available" Availability:"Running or Full Power" Caption:"x64 Family 6 Model 23 Stepping 10" - "Chipset Name":"Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz" Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core2+Duo+CPU+++++E8400++" CPU Speed:"2.00 GHz" Current Voltage:"1.8 volts" Driver:"Not Available" Driver Date:"04/21/2009 12:00 AM" Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys" Driver Provider:"Microsoft" Driver Version:"10.0.18362.1049" Ext. Family:"Not Available" Family:"Not Available" FPO:"Not Available" INF:"cpu.inf" INF Section:"IntelPPM_Inst.NT" Install Date:"Not Available" Last Error Code:"Not Available" Level 1 Cache:"2 x 128 KB" Level 2 Cache:"2 x 6144 KB" Level 3 Cache:"0 MB" Load:"2%" Manufacturer:"GenuineIntel" Model:"23" Name:"Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz" Number of Cores:"2" Number of Cores Enabled:"2" Number of Logical Processors:"2" Part Number:"Not Available" Power Management Capabilities:"Not Available" Power Management Supported:"No" Processor ID:"BFEBFBFF0001067A" Revision:"5898" Serial Number:"Not Available" Service Name:"intelppm" Status:"OK" Stepping:"10" Version:"Not Available" - "Storage" - "TOSHIBA MQ01ABD050" Capablities:"Random Access, Supports Writing, SMART Notification" Caption:"TOSHIBA MQ01ABD050" Cylinder - Total:"60801" Description:"Disk drive" Driver:"Not Available" Driver Date:"06/21/2006 12:00 AM" Driver Version:"10.0.18362.1" Error Code:"Device is working properly" Firmware Revision:"AX0D5A" Heads - Total:"255" Index:"0" INF:"disk.inf" Install Date:"Not Available" Interface Type:"IDE" Manufacturer:"(Standard disk drives)" Model:"TOSHIBA MQ01ABD050" Name:"\\.\PHYSICALDRIVE0" Partitions:"2" Physical Sector Size:"4096" PNP Device ID:"SCSI\DISK&VEN_TOSHIBA&PROD_MQ01ABD050\4&10F2CB4F&0&000000" Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available" Sectors - Per Track:"63" Sectors - Total:"976768065" Serial Number:"Z5LZTE9CT" Size:"465.76 GB" Size – Available:"301.48 GB" SMART Attributes:"Self-Test: 120 minutes, OK, Short Self-Test: 2 minutes, OK" Status:"OK" Tracks - Per Cylinder:"255" Tracks - Total:"15504255" - "C:" Availability:"Not Available" Caption:"C:" Compression Method:"Not Compressed" Description:"Local Fixed Disk" File System:"NTFS" Name:"Not Available" Serial Number:"4A4FE7A8" Size:"465.27 GB" Size – Available:"301.48 GB" Status:"Not Available" Volume Dirty:"No" - "SMART" 0x01 Raw Read Error Rate:0:"50" 0x02 Throughput Performance:0:"50" 0x03 Spin Up Time:1041:"1" 0x04 Start/Stop Count:473:"0" 0x05 Reallocated Sector Count:0:"50" 0x07 Seek Error Rate:0:"50" 0x08 Seek Timer Performance:0:"50" 0x09 Power-On Hours:514:"0" 0x0A Spin Retry Count:0:"30" 0x0C Power Cycle Count:337:"0" 0xBF G-sense Rate/Servo Tracking:125:"0" 0xC0 Unsafe Shutdown Count:27:"0" 0xC1 Load/Unload Cycle Count:8957:"0" 0xC2 Internal Device Temperature:29° C:"0" 0xC4 Reallocation Count:0:"0" 0xC5 Current Pending Errors Count:0:"0" 0xC6 Uncorrectable Sector Count:0:"0" 0xC7 CRC Error Count:0:"0" 0xDC Disk Shift:0:"0" 0xDE Loaded Hours:435:"0" 0xDF Load/Unload Retry Count:0:"0" 0xE0 Load Friction:0:"0" 0xE2 Timed Workload – Media Wear:189:"0" 0xF0 Head Flying Hours:0:"1" ...#SSU#...
AlHill
Your processor and chipset graphics are not supported on Windows 10.  The only driver available is the Microsoft generic graphics driver, which lacks features and performance.
Tremayne
@AlHill
But the thing is that I’ve had windows 10, and it was working fine, idk what I did but I click update drivers and now the resolution is fixed, and I’m pretty sure that there isn’t a way to change a processor without taking it apart so that didn’t happen. The person I bought it from had emulators on it, maybe he did something to make it work? But am I able to restore the pc like 3 days?
Tremayne
Never mind. I don’t know what happened but I turned my computer on and it’s back to normal, anyways thank you for your help and time.
