22873 Discussions
HD 3000, HDMI BSOD Fixed, more bugs leaved
Last driver version 15.22.50 for integrated to CPU video (Core i7-2600 for me) fixed bug with BSOD in igdkmd64.sys on connecting HDMI display, but there are other problems in this release:
My config is Asus P8H67-V motherboard, Core i7-2600 CPU, AMD Radeon 6950 VGA Card, Windows 7 x64.
I use iGPU Multimonitor in BIOS - it enables Both integrated GPU and discrete and is used to connect more displays to PC (use integrated ports to connect displays, but renders and etc works on discrete card).
Problems are:
1. Connected one HDMI Projector to integrated HDMI port and two DVI monitors to discrete card - all works ok, BUT I can not move projector to the right by the main screens, it appears only to the left, then I try to move it to right one or more times screen goes BLACK and only mouse cusor is visible.
2. Connected two HDMI Projector to integrated HDMI port and DVI port by DviToHdmi converter and two DVI monitors to discrete card. Color music begins here: all screen (on integrated and discrete) start blinking asynchronously - first - second - fird - fourth, repeat... Screen goes black and back and repeat...
What to use HDMI port or DVI with DviToHdmi converter does not matter. One work only left of main screen, two not working at all (blinking).
I have not tested working two HDMI monitors only without iGPU and discrete card, but i think what results may be the same. So for beginning just test two HDMI monitors to on integrated card.
I expect a fix, thank you for your attention!
DArce
Valued Contributor III
The options to use the integrated processor graphics and a discrete controller at the same time, depends on the implementation and software that has been used by the motherboard or Original Equipment Manufacturer to achieve this.
In this particular case we suggets you to formward this type of concerns directly to your computer manufacturer for further research.
2 x VGA monitors with previous drivers worked perfect, maybe you or me will test lonely integrated GPU with TWO HDMI monitors?
This thread confirms my info /thread/24946?tstart=0 http://communities.intel.com/thread/24946?tstart=0, With Latest driver Dual digitally connected monitors not working, even without discret video! Any suggestions? And another bug with dual cards - when install driver for discrete radeon card with enabled integrated GPU, screen gooes black and don't come back. Only reboot helps, so the only possible way to install driver - disable integrated gpu in BIOS. This is yours driver problems, not others, so don't kick me out like a ball.
