22980 Discussions
HD 4000 Drivers Result in No DVI Signal Detected
I've just assembled my new desktop computer and after installing Intel's latest HD 4000 drivers (going from basic Microsoft drivers), my monitor is not detected by Intel graphics (connected via a DVI cable), and my monitor does not sense any DVI signal input.
Everything is fine during the BIOS / Windows boot-up sequence (I can see the Starting Windows screen), but then the display goes blank (corresponding to the time Windows Log-on screen should be presented).
  • Can you please advise if there is a setting or something similar I can apply to get my monitor and the Intel graphics DVI output to recognize one another?
NOTE: As a temporary troubleshooting measure I've connected my old VGA monitor which seems to work fine.
Thank you!
/Dragan
Finally, I've extracted the following info from dxdiag in case it's necessary:
System Information
Time of this report: 1/5/2013, 02:25:53
Machine name: DJ-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_rtm.101119-1850)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: To be filled by O.E.M.
BIOS: BIOS Date: 08/22/12 16:24:39 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.9GHz
Memory: 16384MB RAM
Available OS Memory: 16274MB RAM
Page File: 2028MB used, 30516MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_D0001458&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Curr...
NICHOLAS_F_Intel
Hi dragon0t3,
What model is your Gigabyte* motherboard? Can you try using the VGA/Graphics driver provided by Gigabyte*? Also, are you connecting directly from your display to your system, or going through an AV/R device?
Lastly, on your monitor there should be a button (looks like a box inside another box usually), which is used for switching between display modes (VGA, DVI, HDMI, etc). Have you tried pressing that a few times while the system is up to see if it's just trying to display in the wrong mode?
Let me know if any of this works for you,
-Nic
