23264 Discussions
HD 4000 color profiles & open GL
jmcmi1
Hi
I'm using an HD 4000, with the 10.18.10.3345 driver, and I cannot save Display Color Profiles via the Graphics Control Panel.
When I change the settings, the save profile button becomes unselectable.
Also openGL programs cannot use their full graphical features on the HD 4000
My system is a Samsung series 9 laptop
Kevin_M_Intel
Hi jmcmillen,
This happens because you need to apply the changes first and once this is done, the save profile button will become available.
The Graphics Controller HD 4000 supports OpenGL 4. You can check this information at the following link:
http://www.intel.com/support/graphics/sb/cs-033757.htm http://www.intel.com/support/graphics/sb/cs-033757.htm
I recommend you checking with the software developer since our drivers do support the OpenGL feature.
jmcmi1
Hi Kevin
Thanks, that solved the first problem
But for the OpenGL; for example, when running Quake 3 lightmaps seem to be missing. On Half-Life, it lags in large areas, and Quake 4 barely runs on minimum. (These are all OpenGL)
However, it runs fine with DirectX like Unreal Tournament on high settings
Kevin_M_Intel
Jmcmillen,
The graphics controller you have supports OpenGL 4. The feature is enabled by default at the driver level. My best recommendation is to contact the game developer to enable the OpenGL in the game.
