I just finished building my "dream pc" and I'm currently using the HD 4600 graphics from the i7-4790K until the new Nvidia product line launches. I noticed I am getting green dots flashing on certain textures in some games. So far I've only noticed it in Battlefield 4 and Sim City on certain textures. See screenshot below...
I have all current drivers of everything - UEFI, Windows, Graphics driver, etc.
System specs -
Intel i7-4790K
Asus Hero 7 MB
EVGA Supernova 1000w P2
Corsair Vengeance Pro 16gb 2400
Samsung 840 Pro 512g
Windows 8.1 64
HDMI hooked up to AsusPB278
What I have tried -
Reinstalled graphics drivers, including the Beta for HD4600 as well as previous versions.
Changed every resolution, monitor setting, refresh rate, monitor cable, etc.
I'm not sure what is causing this - I'm hoping its just a driver fix or setting that I can change. Anyone else have this problem? Thanks for the help...
Adam
Hi ahaas5,
I am sorry you are having problems but let me help you.
I would like to get some more information from your system so can you please provide the dxdiag report?
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
Graphics Report: Right click on desktop> Graphics Properties> Options> Drop Down Menu> Information Center> Save> Open .txt file created> Copy/Paste here.
Kevin M
Dxdiag...
System Information
Thanks for the information. We have not received reports from other users related to this so it is an isolate case. However, there are some troubleshooting steps I want you to do:
- Make sure you have the latest BIOS for your board.
- Update the graphics driver to the latest version. Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245
- Install the monitor drivers.
- Test different video cables and if possible do not use adapters (direct connection between the monitor and the board).
- Try the system with a different monitor.
Kevin M
@ ahaas5, Have you had the opportunity to try the latest Intel HD Graphics driver for resolving this issue?
Link for driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348&lang=eng&ProdId=3720 Intel® Download Center
Robert
hi
i too have same problem when i install graphic hd 4600 driver
my computer spec
- Intel® Core™ i7-4700 Desktop Processor
- intel mother board DB85FL
- corsair vs650 SMPS
- 8 GB transcend RAM
- WINDOW 7 64 BIT
- 1 TB HARD DISK
i have monitor flickering problem all the time ,i cant even use computer due to this problem....
when i install graphic driver my system hangs , monitor flickers , pen drive socket disconnects
i tried changing cables,installing latest version in intel website and no electric problems
pl solve my problem, having this problem for about 2 months no one can solve driver problem...
What is the driver version installed on your computer? Also, have you tried updating the BIOS on your computer?
Here is the latest:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24354 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24354
Kevin M
