23102 Discussions
HD 4600 and Matrox Triplehead
KFroy
I'm a little baffled because I can't get HD 4600 to work with standard Triplehead resolutions, like 3840x1024.
The highest available is 2400 x 600, and I've also tried the CustomModeApp.
The Matrox website and compatibility tool indicate that it should work, although the list has not been updated for 4th gen.
http://www.matrox.com/graphics/en/support/compatibility/gxm/resolutions/ Matrox Graphics - Support - GXM Compatibility List
The cabling and monitors have all been used in this setup before with another graphics card.
Any tips..?
Windows 7 x64
Intel driver: 10.18.10.3345
Triplehead2go Digital edition.
Knut Andreas Frøyen
Kevin_M_Intel
Hi Knut_F,
What is connection you are using, is it HDMI? Can you please post your Graphics report here and also the dxdiag?
KFroy
Hi Kevin,
I've tried the regular DVI port with a dual link cable, and I've tried the HDMI port with an adapter to DVI-I and the same dual link cable.
DXDIAG:
System Information
Time of this report: 1/6/2014, 08:52:24
Machine name: GEMINI
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 10/29/13 14:51:47 Ver: 16.02
Processor: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 32768MB RAM
Available OS Memory: 32448MB RAM
Page File: 1903MB used, 31566MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: The file scScope.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_85341043&REV_06
Display Memory: 1760 MB
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 2400 x 600 (32 bit) (60Hz)
Monitor Name: Matrox TripleHead2Go Digital Edition
Monitor Model: unknown
Monitor Id: MTX0511
Native Mode: unknown
Output Type: HDMI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3345 (English)
Driver Version: 10.18.10.3345
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/28/2013 14:06:34, 12151296 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-E27E-3EA5BBC2C735}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x85341043
Revision ID: 0x0006
Driver Strong Name: oem14.inf:IntelGfx.NTamd64.6.1:iHSWD_w7:10.18.10.3345:pci\ven_8086&dev_0412
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: For...
KFroy
Graphics report:
Report Date: 1/6/2014
Report Time[hh:mm:ss]: 09:23:21
Operating System: Microsoft Windows 7 Ultimate (6.1.7601)
Default Language: Norwegian, Bokmål (Norway)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 32447 MB
Processor Speed: 3400 MHz
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
Video BIOS: 2170.0
Current Graphics Mode: 2400 by 600
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
* Digital Display *
Display Type: Digital
Connector Type: HDMI
Serial Number: MTX0511
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Digital Display
Maximum Image Size:
Horizontal: 16.14 inches
Vertical: 12.20 inches
Monitor Supported Modes:
640 by 480 (75 Hz)
640 by 480 (60 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1600 by 1200 (60 Hz)
1920 by 480 (60 Hz)
2400 by 600 (60 Hz)
3840 by 720 (60 Hz)
3840 by 1024 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 36 98 11 05 72 8C 64 51
1E 0F 01 03 80 29 1F 78 E8 02 E5 A3 57 4B 9C 25
11 50 54 25 4B 00 A9 40 81 80 01 01 01 01 01 01
01 01 01 01 01 01 57 63 00 88 F0 00 2A 40 10 10
17 00 3A 20 41 00 00 1E E0 2E 60 00 93 58 1C 20
78 E0 17 00 A4 A9 20 00 00 1E 82 1D 80 E0 71 E0
2D 10 30 F0 A5 00 1D 87 20 00 00 18 89 45 00 88
F0 D0 1C 20 10 10 38 00 3A CB 40 00 00 1C 00 BA
* Other names and brands are the property of their respective owners. *
Kevin_M_Intel
Hi Knut_F,
The Graphics controller in your system is capable to get up to 4k resolutions. You can check this information at the following link:
http://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics http://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics
However, it seems that you are using an adapter and the performance can be affected by these type of devices. Since you have your system updated with the latest driver, my recommendation is to test a direct connection (no adapters) between the computer and the monitor and in that way we can discard a problem with your system. So far, since you are not getting the desired resolution, a firmware update for your active adapter can fix the problem or another option is contacting the adapter manufacture and verify with them this behavior.
KFroy
After reading about this, I think I've solved it.
Basically there is no HDMI (A) to DVI dual link whatsoever, they are incompatible.
The triplehead2go needs a dual link because the resolution requires a pixel clock rate above 165 MHz, which is the limit for single link DVI. There are cables and adapters out there with HDMI in one end and DVI-DL in the other, but that is just a marketing bluff. The six center pins on the DVI aren't really connected to anything.
In the future there will be an HDMI (B) connector which is wider, has more pins and is compatible with dual link.
You may close this thread now.
Knut Andreas Frøyen
