I have a motherboard with an integrated HD 530 with a Dell U2410 on Displayport as my second adapter and second monitor. After the monitor goes to sleep at the specified time (15 min), it receives a signal from the video card after 40 seconds that wakes it up, then immediately goes back to power save mode without displaying anything, wakes up immediately again, then goes back to power save mode. It then sleeps for 40 seconds and the process repeats; Sleep for 40 seconds, wake up twice back to back, then sleep for 40 seconds, etc. I have disabled the audio connection to the monitor in Device Manager (Windows 10), but this hasn't helped. I'm using the latest driver for both the monitor and the video adapter, and a premium DP cable. Any ideas?
Try this:
Enter the Menu on the OSD Menu on your monitor (press on LED 4th from top). In the Other Settings disable the DDC/CI (Display Data Channel/Command Interface) .
Leon
That is a great idea - but, unfortunately I had already disabled DCI in earlier troubleshooting. I just checked it again, and it was off.
Please try to disconnect the mouse and keyboard (or if wireless, the wireless receiver), to verify if those devices are not the cause to monitor awake.
Leon
Yes, sorry - got busy. I disconnected all USB devices from the PC and the problem persists. As I mentioned in my original post - the timing is exactly the same every time - 40 seconds - so that strikes me as being some sort of process or polling that is triggering things, rather than being caused by random input.
Scan is attached. The U2410 is my secondary monitor and is connected to the display port on the motherboard via a 1.4/HBR3 VESA certified DP cable. There is also a NVIDIA GTX 1080 Ti for the primary monitor, which is an Alienware AW3418DW and it is also connected with a similar DP cable.
