22965 Discussions
HD Graphics 2000 i5 2400s 3D display rendering glitch, pics
I have the i5 2400s in a gigabyte GA-H67MA-D2H-B3 board. Trying to run J River Media center.
Everything runs ok, video, graphics benchmarks, windows experience index; but when I try to enter some 3D mode displays in the JRMC, the display is faulty. Full screen theater display uses 3D graphics, and is a blank (black) screen; small screen 3D displays only a corner of what should be rendered.
It has been suggested the 3D driver is the problem. I've updated the driver to the latest driver (...2321, as below).
Here's a discription, and the thread has some snips that show the problem:
http://yabb.jriver.com/interact/index.php?topic=63451.0 http://yabb.jriver.com/interact/index.php?topic=63451.0
I've tried switched to Vertex software rendering in the 3D panel, but that makes no difference.
Any ideas?
following is the system info from the intel graphics control panel:
Intel(R) HD Graphics 2000 Report Date: 4/5/2011Report Time[hr:mm:ss]: 17:12:54Driver Version: 8.15.10.2321Operating System: Windows 7 Service Pack 1(6.1.7601)Default Language: English (United States)DirectX* Version: 10.1Physical Memory: 7693 MBMinimum Graphics Memory: 480 MBMaximum Graphics Memory: 1760 MBGraphics Memory in Use: 107 MBProcessor: Intel64 Family 6 Model 42 Stepping 7Processor Speed: 2494 MHzVendor ID: 8086Device ID: 0102Device Revision: 09 * Processor Graphics Information * Processor Graphics in Use: Intel(R) HD Graphics 2000Video BIOS: 2080.0Current Graphics Mode: 1280 by 1024 * Devices Connected to the Graphics Accelerator * Active Digital Displays: 1* Digital Display * Monitor Name: Generic PnP MonitorDisplay Type: DigitalGamma Value: 2.2DDC2 Protocol: Supported Maximum Image Size:Horizontal: 13.39 inchesVertical: 10.63 inches Monitor Supported Modes:640 by 480 (67 Hz)640 by 480 (75 Hz)640 by 480 (72 Hz)640 by 480 (60 Hz)720 by 400 (70 Hz)800 by 600 (72 Hz)800 by 600 (75 Hz)800 by 600 (56 Hz)800 by 600 (60 Hz)832 by 624 (75 Hz)1024 by 768 (75 Hz)1024 by 768 (70 Hz)1024 by 768 (60 Hz)1152 by 864 (75 Hz)1152 by 870 (75 Hz)1280 by 1024 (75 Hz)1280 by 960 (60 Hz)1280 by 1024 (60 Hz) Display Power Management Support:Standby Mode: Not SupportedSuspend Mode: Not SupportedActive Off Mode: Supported Raw EDID:00 FF FF FF FF FF FF 00 4C 2D 92 01 37 31 49 42 0A 0F 01 03 80 22 1B 78 2A AA A5 A6 54 54 99 26 14 50 54 BF EF 80 81 80 81 40 71 4F 01 01 01 01 01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70 13 00 52 0E 11 00 00 1E 00 00 00 FD 00 38 4B 1E 51 0E 00 0A 20 20 20 20 20 20 00 00 00 FC 00 53 79 6E 63 4D 61 73 74 65 72 0A 20 20 00 00 00 FF 00 48 43 4A 59 33 32 35 30 35 34 0A 20 20 00 0E * Other names and brands are the property of their respective owners. *
Setting it to low resolution, seems that any anti-aliasing leads to trouble.
Surprising, since this chip is supposed to support this.
see here:
http://yabb.jriver.com/interact/index.php?topic=63426 http://yabb.jriver.com/interact/index.php?topic=63426
More info in the thread referenced above:
We have an H67 here now, and see the same issue: using AA (anti-aliasing) causes a black screen. It's not even possible to render simple text overlays.
The frustrating thing is that the driver is explicitly saying is supports AA in a call to CheckDeviceMultiSampleType(...). Even using 2x AA causes the black screen.
We're looking for a workaround, or at least a way to disable AA on Intel GPUs.
If anyone has a contact at Intel, we'd appreciate it.
I have submitted a support request to intel about this issue, and to gigabyte.
