23800 Discussions
HD Graphics 4600 and Auria EQ276W Monitor Resolution Issue
JPlum
I just built a new machine with the integrated HD graphics 4600. It's connected to an Auria 27" EQ276W monitor via DVI cable. Currently only a single monitor, but will have two monitors once I get the resolution issue fixed. This monitor supports 2560 x 1440 via DVI, but on this setup the top resolution I'm able to get is 1920 x 1080.
Obvious question then is how can I get the support for 2560 x 1440??
Thank you.
Here's the graphics information report:
Intel(R) HD Graphics 4600
Report Date: Monday, May 04, 2015
Report Time [hh:mm:ss]: 12:34:50 PM
Driver Version: 10.18.14.4170
Operating System: Windows* 7 Professional (6.1.7601)
Default Language: English (United States)
Physical Memory: 15821 MB
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
Video BIOS: 1035.0
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Processor Speed: 3500 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 11.0
Hardware-Supported Version: 11.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Display *
Display Type: Digital
Serial Number: YU2012010001
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Display
Maximum Image Size
Horizontal Size: 23.62 inches
Vertical Size: 13.39 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (75p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1440 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
2560 x 1440 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 5D F2 60 27 00 00 00 00
01 16 01 04 A1 3C 22 78 3A 6F B1 A7 55 4C 9E 25
0C 50 54 A5 CB 00 71 4F 81 C0 81 80 95 00 B3 00
D1 C0 01 01 01 01 56 5E 00 A0 A0 A0 29 50 30 20
35 00 55 50 21 00 00 1E 00 00 00 FF 00 59 55 32
30 31 32 30 31 30 30 30 31 0A 00 00 00 FD 00 17
4C 0F 63 19 00 0A 20 20 20 20 20 20 00 00 00 FC
00 54 42 44 0A 20 20 20 20 20 20 20 20 20 00 70
* Other names and brands are the property of their respective owners.
JPlum
FYI I tried the setup with an HDMI cable and the the 2560 x 1440 resolution works.
JPlum
Jose_H_Intel1
It could be related to the cable. We suggest a high quality straight HDMI cable.
Is the monitor model properly detected in Device Manager?
JPlum
Yeah, we tried HDMI and then it worked. However, this monitor had previously worked fine with a DVI cable and an Invidia GT9500 card, so was surprised it didn't work with the HD Graphics 4600. We also allocated 512mb of RAM.
