23269 Discussions
HD Graphics 530 crash with windows 10 / Dell laptop
DRatn
Dell laptop XPS 15 9550 running Windows 10 Home, approximately 9 months old.
Getting a Windows blue screen crash (stop code 0x00000063) on a regular basis which went away when the Intel HD Graphics 530 driver was disabled.
How come, and what's the fix so that the driver can be re-enabled?
Hello davidhratner,
I understand you are getting blue screen of death in your Dell* laptop, and the issue goes away when you disable the Intel graphics driver.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Was there any software or hardware change before the issue started happening?
Does the issue happen when you are doing something in specific in the computer?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello davidhratner,
I was wondering if you still need assistance regarding the blue screen of death issue. In case you need further assistance just let me know.
Fred D.
