Hello, I'm working on a Panasonic CF-31 laptop with Intel HD graphics 5500. I've got everything working well, with exception to the display. It refuses to change brightness only while on battery. I believe it is a Windows Update/display driver incompatibility, but maybe someone has an idea of how to get past it.
Included is a print screen of what I have thus far.
I tried several of the Intel Install tools, all of them claimed system incompatibility.
Intel® Graphics Driver for Windows* [15.33]
Intel® HD Graphics Production Driver for Windows® 10, 64-bit* (N-Series)
Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] (latest)
The latest driver I can get is the one on the print screen, 20.19.15.5058
If I do a fresh install of Windows 10, before the updates, with an older driver, it works. I can change brightness. After Windows update, even with older driver it doesn't work anymore. I rolled back system updates to no avail. The slider moves but nothing on the screen changes.
I've looked for adaptive settings and battery saver settings and disabled them all. The brightness will change when the power adapter is plugged in before the system is started. On battery, when booted it will not change.
I've tried modifying the registry key to f008 and fb20, nothing.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000
The Intel firmware has been upgraded, as well as the Bios and TPM. If I do all Windows updates, it is not fixed.
When I tried tried the Intel DSA, it does not give a graphics update option. It does give an option for updating bluetooth and something else. When I did those updates, the computer bluescreened on the next reboot. So I wiped windows and tried again.
Chkdsk shows no errors either.
Help or tips appreciated, thanks!
I forgot to mention am running Windows 10 64-bit system with
Intel(R) Core(TM) i5-5300U CPU @ 2.30G
Hello @Anonymous
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it. You may also find the Discontinued Products website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Jose B.
Latest driver is 20.19.15.5171
Here you go:
https://www.intel.com/content/www/us/en/download/18369/intel-graphics-driver-for-windows-15-40.html
Thanks for getting back to me!
I was able to do a driver update to the 2020 version. It is still not working at the moment, but it is an improvement over what I had. I was unable to find any .zip file with drivers before.
I'm going to redo all the Windows Updates and get back.
Ok, I did all the Windows Updates, with exception to the 'Optional quality update'
2023-10 Cumulative Update Preview for Windows 10 Version 22H2 for x64-based Systems (KB5031445)
The driver is updated to 20.19.15.5171 (shown in printscreen).
I'm still out of ideas. If I change to the crude 'Windows Display Adapter', it does allow me to change brightness in 1 interval. (Bright, not bright)
Any thoughts appreciated. Thanks!
