23102 Discussions
HD4000: dvi problems with 1920x1200 on a LG L245WP
i have a LG L245WP monitor and used it for several years without any problem on ati graphic cards via dvi port - directly or with a digitus ds-11802-1 kvm-switch. now i would like to use the ivy bridge hd4000 graphic, but i got problems...
the hd4000 graphics seems not to be able to support a signal quality, which is suffizient for the full 1920x1200 @ 60Hz resolution.
if i boot and go into the uefi bios setup, the monitor shows only a part of the expected screen. the left and top margins of the image are missing. i have the same problem after booting into windows. if i reduce the resolution to 1680x1050 i got a black screen. i have no problems with very low-end resolutions like 1280x800. in 1280x800 only some horizontally lines popup if i move a window fastly with my mouse...
i installed the lg .inf monitor driver, but the intel graphic controll center still detects my l245wp tft as tv.. ?
the situations gets better, if i use my digitus ds-11802-1 kvm-switch between the mb dvi port and my tft. now the screen image is correct, but some snow appears in some areas of the picture. this problem is gone, if i reduce the resolution or the frequency via creation of a custom resolution. 1920x1200 @ 50 Hz is working in this mode. sadly the monitor makes some dimming noise in that mode...
so it seems, that the hd4000 isn't able to support a signal quality good enough for my tft...? i haven't expected that i must buy a new tft for hd4000 graphics! is that a common problem with 1920x1200 dvi single link? in ati graphics control center i had options for reducing the dvi frequency and using an alternate mode, but this was not necessary. now i miss such options in the intel graphic control.
i have the following system:
Asus P8Z77-M
Intel 3570K
8 GB DDR3-1600 RAM
LG L245WP Monitor with a native resolution of 1920x1200 @ 60Hz
monitor has vga and hdmi input. it was and is equiped with a dvi to hdmi display cable.
Win7 64 bit (and Ubuntu 12.04, the same problems..)
I use the latest bios and intel drivers (graphic driver V815102669) from the asus website. the graphic driver seems to be newer than that one from intel download center.
i found this thread:
http://forums.nvidia.com/index.php?s=81c339d50cb13b3ce0676542dea6e5e0&showtopic=58483 HDMI: How to disable? - NVIDIA Forums
so the problem seems to be, that the monitor has an hdmi input but dvi pc connector and the advertising itself as an HDTV.
nvidia cards had some trouble with such tft's too. ati has fixed that problem.
