23270 Discussions
HD4400 i3 4150 signal blinks in 1080p gaming
mm13
when gaming at 1920x1080 1080p fullscreen whenever there is heavy action going on in game cpu gpu usage goes up, my screen would blink once or twice as if turning on/off v-sync but the blink lasts a little longer maybe half a second compared to actually turning on/off v-sync,I tried every connector on my asrock z97 extreme4 hdmi/displayport/dvi/vga.
I was using an older monitor via dvi 1280x1024 native res and no issues, I have tried most of the drivers from intel 3670, 4080, 4156.
I always reformat and install win 7 x64 fresh when trying out new drivers.
Silvia_L_Intel1
Hello Hjin, thanks for joining the Intel Community.
I would need to get information about your system so please attach the DX Diag report? (Start -> Run -> dxdiag -> Save All Information).
I would also need to know the model number of the old monitor and also the model of the new monitor you are using?
mm13
the monitors I've tried
Dell U2414H via hdmi and previously Samsung SyncMaster 731BF via dvi.
System Information
Time of this report: 3/31/2015, 21:45:12
Machine name: TEST-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150202-1526)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 12/17/14 20:03:01 Ver: 04.06.05
Processor: Intel(R) Core(TM) i3-4150 CPU @ 3.50GHz (4 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16084MB RAM
Page File: 2435MB used, 14669MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4400
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_041E&SUBSYS_041E1849&REV_06
Display Memory: 1760 MB
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SyncMaster
Monitor Id: SAM0216
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HDMI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0014.4156 (English)
Driver Version: 10.18.14.4156
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 3/3/2015 10:41:16, 24802928 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-475E-11CF-C56B-1024BBC2C735}
Vendor ID: 0x8086
Device ID: 0x041E
SubSys ID: 0x041E1849
Revision ID: 0x0006
Driver Strong Name: oem5.inf:IntelGfx.NTamd64.6.1:iHSWD_w7:10.18.14.4156:pci\ven_8086&dev_041e
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0...
Silvia_L_Intel1
Thanks for the information, Hjin.
Some recommendations I could give you are the following:
Update the Chipset driver to the latest version available.
Update the management engine and BIOS. http://www.asrock.com/mb/Intel/Z97%20Extreme4/?cat=Download http://www.asrock.com/mb/Intel/Z97%20Extreme4/?cat=Download
I would also recommend you to install the monitor driver http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=YVPMR http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=YVPMR
Let me know the results,
mm13
I was in bios and the screen started blanking out, both monitors connected and the one at 1080p blanks out for a second or two. is there a problem with the cpu since I wasn't even in windows.
Silvia_L_Intel1
Hjin, could you please try lowering the refresh rate to 59hz?
mm13
I updated the bios,management engine and chipset drivers same issue the monitor at 1920x1080 is still blanking out. even in desktop doing nothing
I tried dual monitors dell u2414h and samsung 732bf, the blanking happens at 1920x1080 I don't have a 1440p monitor but I suspect it would blank out too, the other issue is when the main monitor is loading something in game the secondary display will flicker.
System Information
Time of this report: 4/4/2015, 07:19:37
BIOS: BIOS Date: 03/13/15 15:20:24 Ver: 04.06.05
Memory: 16384MB RAM
Page File: 1998MB used, 15107MB available
DxDiag Notes
Sound Tab 3: No problems found.
Display Devices
DAC type: Internal
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Dell U2414H(HDMI2)
Monitor Model: DELL U2414H
Monitor Id: DELA0B2
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x8086
Device ID: 0x041E
Revision ID: 0x0006
