23262 Discussions
HD4600 crashes on Windows 10 TP 10049
BLuo3
I am using Toshiba P50t-B with HD4600 and AMD R9 M265x. After upgrading to Windows 10 TP 10049 from Windows 8.1, it works well at first. After using for some time, some Windows become a mess and then the graphics crash if you continue using it.
Driver and system info:
Intel(R) HD Graphics 4600
Report Date: Thursday, April 16, 2015
Report Time [hh:mm:ss]: 6:57:56 PM
Driver Version: 10.18.15.4124
Operating System: Windows* 8.1 (6.3.10049)
Default Language: Chinese (Simplified, China)
Physical Memory: 16294 MB
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
Graphics Output Protocol (GOP) Version: 5.0.1035
Current Resolution: 3840 x 2160
Processor: Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz
Processor Speed: 2494 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.78 inches
Vertical Size: 7.48 inches
Supported Modes
3840 x 2160 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 4D 10 14 14 00 00 00 00
05 18 01 04 A5 23 13 78 06 DE 50 A3 54 4C 99 26
0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 4D D0 00 A0 F0 70 3E 80 30 20
35 00 5A C2 10 00 00 18 00 00 00 10 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FC
00 4C 51 31 35 36 44 31 4A 58 30 31 0A 20 00 78
* Other names and brands are the property of their respective owners.
Though the info above shows that it's windows 8.1, the system is actually Win10 10049.
Kevin_M_Intel
Hello Bruce55,
Windows 10 is not certified Operating System yet so we do not have drivers for our controllers. Please try with Windows 8.1 or another compatible Operating System for your device and let me know how it goes.
Kevin m
