- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
We are a manufacturer of video scaler with built-in HDMI 2.0 Rx chipset.
Our affiliated company reported the following, so I will ask three questions including what I investigated.
For HDMI output with audio from NUC pc, if user do the play -> stop -> play action,
Audio recovery takes up to 6 seconds.
For example, it means that video playback and pause are repeatedly performed every 10 seconds without changing the type of clip on YouTube.
Analysis of the problem found that sck and ws signal of I2S audio disappeared.
The problem only occurred on Intel iRIS graphics models.
So when we tested the reproduction with the specifications described below, it took up to 1 second to recover the audio.
11th Gen Intel i5-1155G7 2.5Gh
Win10 Pro(21H1)
LG Notebook : Gram 15ZD95P-GX56K
In conclusion, the result of extracting and analyzing audio data from our HDMI 2.0 Rx is that
(*) If there is no audio data stream of about 5 seconds, system artificially blocks audio sck and WS (=LRCLK) output.
(**) It appears that there is a routine to detect when the audio menu is retrieved from the window control panel.
Q1)
Is this a behavior intended by Intel?
Or is the procedure in MS Windows-10 controlling HDMI embedded audio?
Q2)
Regarding HDMI embedded audio, are there any updates to the latest bios or drivers?
Q3)
Is it related to the previous QnA of other users below?
https://community.intel.com/t5/Graphics/HDMI-audio-stream-keeps-dropping-when-inactive/m-p/447426
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DHYang,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Iris® Xe Graphics eligible.
1. Can you provide more details about the issue?
2. can you provide a video where we can see the issue?
3. Can you provide specific steps to replicate the issue?
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Please refer to the attached pdf.
Please refer to the attached mp4.
It is a file generated by a customer company in Taiwan,
and if you look at the 6-9 second section, there is a delay of about 3~4 seconds.
When I tested(replicate) it, the delay was up to 1 second.
Please note that there may be more reasons for the customer's own creation.
It was reported by 'NUC11PAH' or 'Redmi Book Pro15' device.
I am reporting the expected cause by testing it with LG laptop which has something in common.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DHYang,
Thanks for the additional information. Before we continue further, I would like to confirm the following:
1. Does the same issue happens on youtube videos? Or is it only present on Windows media?
2. Is this issue recent? Or is it out of the box?
3. Please try a clean install of the Intel drivers:
- Driver: https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
- Steps: https://www.intel.com/content/www/us/en/support/articles/000057389.html
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
My case appeared when I tested it on YouTube.
The same is expected for our customers.
Also, I told our client to test the corresponding matter.
Yes. recent.
Yes. OOTB. Test after initialize the laptop (win-10)
3. Please try a clean install of the Intel drivers: I try it. but equal.
31.0.101.1999 --> 31.0.101.3790 (old driver delete -> install)
Also, I contacted a Taiwanese customer to test the latest driver after installing it.
I'll report when I get the results.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DHYang,
Thanks for the confirmation. I will proceed with the investigation once you confirm if the issue persists with the latest driver.
If the issue persists with the latest Intel drivers, please provide the Intel® System Support Utility (Intel® SSU) report.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
1. The pc used to reproduce the problem phenomenon is not my equipment, so I can't test it right away.
2. Today is a holiday in Korea. You have to wait 2-3 days.
It hasn't been solved yet
I'll upload it after scanning
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Scan file included. Thank you
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DHYang,
Thanks for the update. In this case, based on your report you are running Windows 10 version 19043 and the latest is 22H2 -10.0.19045.2251.
Try to update your Windows version to the latest and let me know if the issue persisted.
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
1. After the Windows version update, the problem has disappeared from the laptop we have.
2. I have asked the customer to check if it is improved in 22H2. I'll leave a message when the result comes out.
The client company noticed me that there was a problem under the conditions below.
#a. Customer's windows version
Redmi Book Pro 15: Windows 10 Home China*(21H2)
NUC: Windows 10 Enterprise LTSC*(1809)
#b. Intel(R) lris(R) Xe Graphics. (Don't care)
Redmi Book Pro 15: 27.20.100.8935 or new version
NUC: 31.0.101.3616 or new version
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DHYang,
I am glad to know that the issue has disappeared from your laptop with the latest Windows version. I will be waiting for the update related to your customer's units.
Thanks for your help.
Deivid A.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
On the issue we are discussing, normal window is OK after update of 22H2 version.
How can we solve or avoid problems in this situation?
This includes Intel communicating directly with Microsoft to provide patches (such as prefixes).
I don't think MS will respond well if I request it...(T.T)
I'm just an employee of a small company.... But Intel's business is huge.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DHYang,
Thanks for the confirmation. In this, Windows 10 Enterprise LTSC is an operating system mainly for companies and Microsoft is the one that provides the driver, updates, and support for this operating system since it runs some customized drivers.
Your client must go with Microsoft to confirm if there is a new version/build of Windows 10 Enterprise LTSC as well as for installation instructions.
You can get in contact with Microsoft using the following link: https://support.microsoft.com/en-us
Deivid A.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
