23077 Discussions
HDMI to VGA no longer works.
TJeps
I have the Intel R HD graphics 3000 on Windows 10, and it worked just fine on Windows 7 and I tested everything on my moms Windows 8 laptop, my dual screen worked just fine. Now it won't even detect the screen, and everyone keeps saying it's the driver that is causing it. Any help?
My computer has the HDMI input and my second monitor has a VGA output, and the adapter works fine as it works on all my other computers/laptops.
Kevin_M_Intel
Hello Thomje112,
At this point we do not have available Windows 10 drivers for HD 3000. My recommendation is to run all Windows Updates.
I have seen other customers uninstall the Intel® HD Graphics and use the standard VGA adapter so you can also try this as a workaround.
My recommendation is going back to a supported Operating System for this controller. Here you can check the Operating System compatibility:
http://www.intel.com/support/graphics/sb/CS-034343.htm http://www.intel.com/support/graphics/sb/CS-034343.htm
Kevin M
TJeps
Are there plans of creating a Windows 10 card for the 3000 series?
And as far as uninstalling it, I would just go to the device manager and uninstall it?
