23257 Discussions
HI, i need help with directx
AJaha1
i have directx 12, because i upgraded to win 10. But the maximum directx support is 11.1
can you help me with that?
EstebanA_C_Intel
Hello, Minor25:
The support for this technology would rely on the hardware you have, my recommendation would be to check the link below.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html Supported Graphics APIs and Features for Graphics Drivers
There you will find the different graphics related technologies supported by the different Intel® Processors.
In order to check the generation of the processor you have, you can do it by following the steps below:
1. Find the model of your CPU (windows key + R and type msinfo32, hit ok and a window shold be prompt with the CPU and other components in your PC.
2. If your processor is from the Core i family, the first number after the "-" will indicate the generation.
http://www.intel.com/content/www/us/en/processors/processor-numbers.html Intel® Processor Numbers: Laptop, Desktop, and Mobile Device
NOTE: If you are using a dedicated graphics card (GPU) you would require to check it's specs for compatibility check with DirectX).
Esteban C
AJaha1
EstebanA_C_Intel
Hello, Minor25:
Thank you for the information provided and I would like to apologize for the delay on my response.
I would like to inform you that the Intel® HD Graphics 4600 which are the graphics present in your Intel® Core™ i5-4690K Processor support up to DirectX* 11.1
Here you can confirm this information and some additional APIs supported by the system (you would require to select "4th Generation Intel® Core™ Processors")
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html Supported APIs and Features for Intel® Graphics Drivers
If you require any further information or support, feel free to contact us back.
Esteban C
