20623 Discussions
How can I download the Intel DCH driver 25.20.100.6444? When I try to install from the Intel site, this error pops up here (see photo). I downloaded the driver here: https://downloadcenter.intel.com/en/download/28148/Intel-Graphics-Windows-10-DCH-Drivers
Translation: The driver to be installed is not valid for this computer. Please obtain the appropriate driver from the manufacturer. Installation will be terminated. Need more information? Click "Yes" to go to the Intel support website.
GSlaz
have the same problem
I have Dell XPS 9570
Intel UHD 630
DLuts
Delete previous graphic driver and reboot system.
HKlum
Valued Contributor I
Since this driver Windows fails to do an update every day and spams the logs wanting to install:
Installationsfehler: Die Installation des folgenden Updates ist mit Fehler 0x80246013 fehlgeschlagen: 9NCGJX5QLP9M-AppUp.IntelMediaSDKDFP
"Delete previous graphic driver and reboot system." that is not enough btw, you have to hide the updates otherwise Windows will always roll back and mess up the entire system:
https://www.reddit.com/r/Windows10/comments/a1pyi8/thank_you_windows_10_ms_for_rolling_back_older/
DLuts
All I know, that yesterday I tried to do this and had the same problem. For me helped go to the apps, delete driver, reboot, install new one.
RAJU2529
New Contributor III
