Hi expert,
I would like to dump video bios with the way mentioned in this link:
https://01.org/linuxgraphics/documentation/development/how-dump-video-bios
it is something like this:
- echo 1 > /sys/devices/pci0000:00/0000:00:02.0/rom
- cat /sys/devices/pci0000:00/0000:00:02.0/rom > vbios.dump
- echo 0 > /sys/devices/pci0000:00/0000:00:02.0/rom
when I run the second cmd "cat /sys/devices/pci0000:00/0000:00:02.0/rom > vbios.dump"
, an error is reported as below:
Invalid PCI ROM header signature: expecting 0xaa55, got 0xffff
I searched the linux source code, it looks like this error is reported from function pci_get_rom_size() in drivers/pci/rom.c
Does this mean there is a bug of driver of Intel HD Graphic 630 or a bug in linux system?
I also searched https://www.techpowerup.com/vgabios/
This is a site which hold much video bios of different VGA CARDs, but I did not find video bios of Intel HD Graphic 630.
So my question is how can I get/dump video bios of Intel HD Graphic 630?
I know that video bios should be updated together with system bios, that is another topic, I need the video bios to run guestos in my hypervisor.
Best Regards
Rocky
Hello mwang82,
Thank you for posting on the Intel ® communities.
I would like to inform you that Intel® does not provide direct downloads and technical support for Linux drivers. The Intel® Graphics Linux driver is primarily supported through the original equipment manufacturer (OEM), the Linux distribution vendor, or by the Intel Open Source Technology Center at 01.org/linuxgraphics.
See the Drivers for Linux document for more details.
Let us know if you have any additional request.
Esteban Ch.
A Contingent Worker at Intel
Hello mwang82,
I was checking your case, and I would like to know if you need further assistance?
Esteban Ch.
Hi Esteban, thanks for your help on this, I'm clear with this case now.
Hi, mwang82. You said that you figured it out, and I was wondering what you did. I am also having this problem and am unable to dump my bios. Thanks!
