23801 Discussions
How to set some settings on Graphic Card without Intel Graphics Commander Center
MScho18
Hi i like to know how to make some settings without the Graphics commander Center.
Background , I do not have the Graphics commander center :
  1. Because Microsoft App Store is blocked in the companies policies
  2. I like to clone the PC with Image software and i always receive error message from the Graphics command Center when the Image is running on new Hardware, but it is always the equal NUC.
Mostly i need setting for:
  1. Video > Film Mode Detection= off
  2. Video > Skin Tone Enhancement = off
  3. Video > Contrast Enhancement = off
n_scott_pearson
Good question! Did no one think about the enterprise environment before making this decision?
Is there a way to download (from Intel, not Microsoft) and manually install the Command Center?
Added bonus question for intel: In light of Microsoft's decision to start forcing updates, should this make a difference in your enterprise-level management?
AndrewG_Intel
Hello all,
Regarding your inquiries, we would like to share the following details:
1- Setting and changing settings on an Intel® Graphics Card without Intel® Graphics Commander Center (Intel® GCC):
Some settings may be changed via Windows Registry or custom .inf installer. However, for assistance regarding how to perform this, users/IT teams need to contact their Original Equipment Manufacturer (OEM) and work directly with them.
2- Manually download of the Intel® Graphics Command Center from Intel® (not Microsoft):
Intel® GCC cannot be downloaded from Intel® ( downloadcenter.intel.com ). In this case, we recommend contacting the OEM as they may have access to a Legacy driver (i.e. has Intel® GCC bundled). Alternately you can check this article as you may want to explore the Device Update Center offered by Microsoft* and work with them on it.
3- In light of Microsoft's decision to start forcing updates, should this make a difference in the enterprise-level management?
It is worth mentioning that this decision is driven by Microsoft* and their UWP platform. We recommend forwarding this concern with Microsoft*
Andrew G.
A Contingent Worker at Intel
