23108 Discussions
I CANT INSTALL INTEL HD GRAPHICS 3000
I ALREADY UNINSTALLED THE PREVIOUS ONE AND DID A REBOOT, BUT NOTHING HAPPENED still gives me error
Jkuma7
It would be good to paste what error you are getting, so that forum members could help you out.
Matthias_H_Intel
but anyways, you ended up the wrong forum - unless you planned to install Intel HD Graphics 3000 on Intel Edison
The Graphics Drivers says "Unknown Device", and i uninstalled it
When I Try to install intel HD graphics from https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24696&lang=eng&ProdId=3319 Intel® Download Center it says "The Setup program failed to install one or more device drivers."
I Also Tried Installing it forcefully by opening Device Manager and it says "Access Denied",
I Also did the install in Safe Mode, and it worked, but after the Reboot, it says that the device is not working properly.
Silvia_L_Intel1
ArtStyle, did you try this manual driver installation method?
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
http://www.intel.com/support/graphics/sb/CS-033916.htm http://www.intel.com/support/graphics/sb/CS-033916.htm
What is the driver version that appears to be causing the issue? Did it ever work before?
Does a previous driver version work?
DxDiag report (press Windows* key + R key, type "dxdiag", press OK and then click "Save All Information").
