20589 Discussions
I accidentaly deleted SoundMAX a week ago and i can't get it back. Can you help me?
I deled SoundMAX not to long ago on accident, and it just so turned out that i now have no sound. I try downloading it again, and it says Driver not found, please reboot your system and try it again. Does intel have Integrated Audio? Can anyone help me?
Hi there,
Without knowing the motherboard model it is difficult to guide you to the exact link to the driver download. You may try this link and see it can find the appropriate drivers for your board: http://support.intel.com/support/motherboards/desktop/detect.htm
Please note this will work only if you are using intel motherboard and not OEM boards.
Also you may try to follow the troubleshooting steps in the following link. It is very well documented and may help you to solve the audio driver issue you are having: http://support.intel.com/support/motherboards/desktop/sb/CS-020642.htm
Advice: You may have to disconnect any front panel audio if there are any connected, during troubleshooting and update the BIOS if necessary.
Cheers
