22364 Discussions
I also cannot play 4K Starcraft remastered with ARC A770
Cenes
I'm asking again because someone else asked the same question but it didn't solve.
When playing Starcraft remastered, I can play with 4K when playing with AMD 6800XT, but I can't play with 4K when playing with ARCA770. (See attached file)
And the in the video option cannot activate the "real time lighting" option and displays a message that VRAM is insufficient.
Does anyone else have this problem?
My system is as follows;
 CPU : AMD 5800X
 Motherboard : MSI B550M
 RAM : 32G
 Graphics : ARC A770(16G)
 OS : Windows 11(64bit)
1st : AMD RX6800XT
2nd : ARC A770
3rd : Arc A770, Starcraft remastered video option
I installed the driver using ddu and activated the HD graphic option in starcraft remastered option.
Andres_Intel
Hello Cenes,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you are having low-performance issues with your Intel® Arc™ A770 Graphics, I will be happy to help you.
I noticed that you also report another issue with the "real-time lighting" option, please make a new post as seems it is another kind issue and it is not related to the 4k issue, if it is related, so we can troubleshoot the second issue on this post.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Cenes
Dear Andres P.
Thank you for your answer.
My answer is :
  • What happens to Starcraft Remastered when you run it at 4K? For example, it crashes, flickers, freezes, low FPS, etc.
  • (There is no other problem except for the resolution problem.  AMD 6800XT displays 4K, ARC A770 displays HD)
  • Was it working before?
  • (Not with an ARC graphics card, but it works well with other graphics cards)
  • Where did you buy the game? For example Steam, Epic, etc.
  • (I purchased in 2020 from Battlenet shop : Starcraft remastered + Cartoon)
I have an Intel 11400 system in addition to the AMD 5800X system. The same phenomenon occurs in the 11400 system.
I don't know if it's a problem with the Blizzard account or ARCA770.   I can play 4K with other graphics cards and only HD quality with ARCA770.
Andres_Intel
Hello Cenes,
Thank you for your response, all the information provided has been really helpful.
I see you provided all the information except the reports, please provide them as they are really important to start with the troubleshooting steps:
Download, run, save and attach the report for the following tools, find the links below:
Andres P.
Cenes
I attach the report file.
I installed a new driver(4502), but it still doesn't work.
Andres_Intel
Hello Cenes,
Thank you for your answer, it has been really helpful.
Please follow the steps below and let me know the results:
Andres P.
Andres_Intel
Hello Cenes,
Andres P.
Andres_Intel
Hello Cenes,
Andres P.
Andres_Intel
Hello Cenes,
Just for you to know Intel is currently investigating this issue.
Andres P.
Andres_Intel
Hello Cenes,
We have been working on the investigation and our development team finished debugging this issue and concluded the root-cause is on the application(game) side. The game code needs to be updated to get optimizations for Intel GPU and drivers hence, we recommend reporting this to the game developers.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
