22468 Discussions
I can't change settings or overclock BOTH of my Arc A770s. Also, what about custom resolutions?
GoldenSun3DS
Arc Control does not allow me to choose which GPU I'm changing settings for (power limit, overclock, etc) and it only seems to apply to the first GPU. Arc does not allow you to use third party programs like MSi Afterburner, either.
Plus, I need fan control. Why doesn't it let me control fan speeds when you block third party tools? When I try to set a custom resolution in Intel Graphics Command to match my phone's resolution (game streaming via Parsec with HDMI dummy), it just gives an error. I had no problems with custom resolution with an inferior GTX 1650 Super and the same HDMI dummy.
https://www.tweaktown.com/news/87886/intel-confirms-arc-graphics-does-not-support-multi-gpu-for-gaming/index.html
Intel had to clarify to the press that Arc supports dual GPU for rendering, not gaming, so why can't I change settings for BOTH of my Arc GPUs? Will third party tools like MSi Afterburner eventually be unblocked so we can use those instead of Arc Control?
The reason I have 2 Arc A770 16GB GPUs is to do a multiseat shared system with 2 users each getting a GPU.
Carlos_L_Intel
Hello @GoldenSun3DS
Thank you for posting on the Intel® communities. Thank you for your feedback.
In order to review this further, could you please provide us with the following details?
  • To clarify, when you are tweaking your main card, it works fine, correct?
  • What is the error you get when trying to set the costume resolution?
  • Please run a graphics report following this article, especially Intel Graphics Command Center (Intel GCC)
  • To get more information from your system please install, run and attach the logs for the following tool: Intel® System Support Utility for Windows. (Please select de 'Everything' checkbox when you run the tool so we have all the information we need)
Carlos L.
Carlos_L_Intel
Hi @GoldenSun3DS
Carlos L.
Carlos_L_Intel
Hi @GoldenSun3DS
Carlos L.
